Penetrating oil what`s your fav.?
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by highdez1981430cr, Mar 10, 2010.
  1. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    please no K-Y jokes
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I like Bel Ray 6in1.:thumbsup:
  3. DoctorDemento Husqvarna
    Lynnwood, WA
    I like PB Blaster for a consumer grade product, but this "Industrial Only" stuff we have at work (sorry forget the name) works awesome!
  4. bower100 Husqvarna
    Wilmington, DE
    '83 250CR - '07 TE450
    TY350Trials-BetaRev3-'77RM250-'80YZ
    Maybe CRC's Screw-loose in a green can?
    Dave
  5. Ruffus Husqvarna
    PB Blaster :thumbsup:
  6. Skoalman Husqvarna
    maryland
    82 & 83 HUS 430WR
    Maico, Penton, KTM, DKW, Rokon, BUL
  7. kzoo Husqvarna
    Michigan
    WR 295
    PB Blaster.
  8. tagalong Husqvarna
    Rome, GA
    PB and Kano Kroil Oil.
  9. A.Breton Husqvarna
    GA
    +1 Kroil is the best I've ever used, works almost instantly, It's a blue tip wrench in a can. PB blaster if I can't find the Kroil.
  10. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    Where are you guys buying the Kroil at?
    I have only seen this stuff in the Eastwood restoration catalog.
    I am currently using a product called SP3 it comes in a 24 oz metal can with a spray bottle pump and it does not stink like PB Blaster!
    I THINK THE PB STANDS FOR PUKE BILE, but it does work pretty good though especially on styrofoam cups.:thumbsup:
  11. andyman Husqvarna
  12. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    Andyman,
    Thanks for the hook up
    Looks like they have all kinds of cool lubes! :cheers: :thumbsup:
  13. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    w/o a doubt this stuff:
    http://www.corrosionx.com/ma_use.html
    i have 3 cans left of the old school stuff from a helicopter plant. i use it for everything including scrubbing gun bores. cleans shotgun bores in two seconds and is non-corrosive. it's busted loose rusted and seized solid caliper pins, truck suspension bolts etc. it flat works.
    after that kroil gets the nod.
    http://www.kanolabs.com/
    i use this stuff as above, mixed with shooters choice it makes a killer bore scrub.
  14. Reddog Husqvarna
    Michigan
    Rust Reaper
  15. ghte Husqvarna
    Bright, Victoria Australia
    Anyone use this stuff on their chain in lieu of chain lube?
  16. pvduke Husqvarna
    ... on the gas...
    no its a penetrant and made to displace stuff heavier than it and its the wrong type of lube for chains. better than nothing but....theres better stuff to use.
  17. ghte Husqvarna
    Thanx Pvduke
  18. pvduke Husqvarna
    ... on the gas...
    anytime mate, oy! :thumbsup:
  19. 440rev Husqvarna
    IL
    I have not tried or endorse any of these, just wasting time
    I'm not going to verify or endorse this. Draw your own conclusions.
    Happy knuckle busting !
    Machinist's Workshop Magazine (March/April or May/June, 2007) actually tested penetrants for break out torque on rusted nuts. Significant results! They are below, as forwarded by an ex-student and professional machinist, Bud Baker.
    They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.
    *Penetrating oil ..... Average load*
    None ..................... 516 pounds
    WD-40 .................. 238 pounds
    PB Blaster ............. 214 pounds
    Liquid Wrench ..... 127 pounds
    Kano Kroil ............ 106 pounds
    ATF-Acetone mix....53 pounds
    The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. Our local machinist group mixed up a batch, and we all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.
    PaulC likes this.
  20. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    Sweet,I am going to mix me up a batch using synthetic ATF and Acetone.
    GREAT POST 440! :thumbsup:
