got the use of a cable from ion so is anyone willing to give tech support if needed when I start making adjustments? PM a contact number and times of day
email sent... does it matter if the air filter isn't freshly cleaned? was set at 105%, 02 sensor hole plug was all black but this is the plug View attachment 8841
I know you told me the 08 only reads F1 but playing around F2 & F3 do seem to have an effect??? TPS reads 996 at close and 4360 at full. pushed read then set at close.??? raised to 110 per the look of the plug.??
set to 110% from 105% - starts easier and 3/4 to full throttle in high RPM's is now much imprproved. cutting throttle after a full twist almost seems to stall the motor lower RPM's may not be as crisp and notice no power increase from 105% set TPS via ibeat but not real comfortable adjusting mech. throttle any advice welcome....
