Photo of CR250 Exhaust Bracket to Pipe
Discussion in 'Vintage/Left Kickers' started by Gord, Mar 26, 2011.
  1. Gord Husqvarna
    New England
    Hello, I am looking for a close up photo of the middle exhaust tab to down tube bracket connection, for a 73 CR250 pipe. With the bracket I purchased came a bolt with a spring on it. The spec illustration doesn't show the spring bolt. The bracket clamps on to the frames down tube. I'm looking for a picture of the connection to the tab welded on the pipe.
    Thanks.
    gabrennan@sbcglobal.net
  2. auto Husqvarna
    NJ,USA
    too many
    Nothing special,the spring goes inbetween the pipe bracket and the tab that comes off the frame bracket.A 6mm bolt goes throug it all.Tighten with a nyloc nut to a point that the spring is collapsed a little.There just tring to isolate the pipe from motor vibs.
  3. Gord Husqvarna
    New England
    Thanks, Makes sense. Just seems like the spring on the bolt is so long, something else should be there. In other words, my bracket and the tab on the pipe line up perfectly and are against each other. (No space between). To incorporate the spring, I will have to seperate them quite a bit, if the spring goes between the two brackets.
