Photos of new 250 motor with valve cover off...
Discussion in '4 Stroke' started by krieg, Nov 19, 2009.
  1. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
    We need a procedure for checking/adjusting valves SOON. The new motor is Jap-like in a bad way. Obviously, the cams will have to come out for shims to be placed... no big deal I suppose. I can't find marks on cam gears sufficient to line things up for a clearance check. Maybe that's because I'm a dumba$$... but I didn't even bother to break out the feeler guages before I popped the cover back on... praying for a manual, or some instructions SOON.
  2. Motosportz CH Sponsor
    Rotate the motor until the lobes are pointed away from the valves and check them with a feeler. if in spec button it up. If not, turn the motor over till those indented marks on the cams line up to each other or are parallel when the piston is TDC. Pop the cams out noting the position, do not turn the motor over at all with the cams out and replace the shims as needed. Drop the cams back in the way they came out. :excuseme:
  3. Last Lap Husqvarna
    West Creek, NJ
    valves
    I see a punch line on the left gear and a dot puched on the right gear. Take the spark plug out, put the bike in second gear. Turn the back tire and watch the exhaust valves as they are opening up (on exhaust stroke) As soon as the intake valves starts to move stop. That's "valve overlap". Mark the flywheel and a spot on the case. Then turn engine 360 degrees so marks line up. That's T.D.C. You can check your intake and exhaust valves, and also look for marks on the gears they should be lined up or facing opposite each other at that point. At least you can check them until a manual shows up. My 310 uses 950mm shims to adjust the valves. They are the same size as a crf450. I'll bet you will have the 750mm shims like the crf250.
  4. Slowpoke Husqvarna
    Southern Ontario
    Based on the pics, it looks like it should be pretty easy to check the valve lash- like Kelly said.
    Might even be a bit easier, as you can come straight in with a feeler as opposed to having to come in at an odd angle on the 04-09 motors.
    R&R-ing the cams will be a bit more work to replace shims, but shouldn't be too bad since you don't have to mess with the cam chain. Looks like about 20 minutes, being careful and taking your time. Won't be a big deal if you only have to do it every 100-200 hours.
    The Key for me is if these motors have the same kind of durability I've been spoiled with on my 07.
  5. Slowpoke Husqvarna
    Southern Ontario
    Are there only 2 bolts holding the valve cover on?
  6. krieg Husqvarna
    Matthews, NC
    Many in the past
    Only 2.
  7. Motosportz CH Sponsor
    A torque spec would be cool for reinstalling the cam caps if you need to re-shim. The rest is all right here. :thumbsup:
  8. john01 Husqvarna
    Powhatan VA
    You guys are good!
  9. Motosportz CH Sponsor
    it's kinda the same thing on all motors like this. Slightly different here and there but same procedure. :thumbsup:
  10. Antz Husqvarna
    Isle of Man
    2010 TE 250 Valve Clearance Check
    Has anybody managed to get any information on cam timing positions to check the valve clearance on the 2010 TE motor?
    Thanks
  11. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    The manual says line the round hole in each cam with the parting lines of the cam caps. There are indents in the gears that should line up and will be in the center, toward each other.
    You are almost there in your bottom picture.
  12. RideLI631 Husqvarna
    LI,NY
    17 FE501, 09 TE510
    Hypermotard, Honda Shadow ,DR650
    I second that most deffinetly get the torque specs for the caps.My ltr450 quad has a very similar valve train witch takes 8- ft.lbs and a very specific manufacturers note in the service manual stating specifically to not over tighten. My local dealer also stressed this as well. Torque is key
  13. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    They show no specs for the cam cover bolts, so they must fall under the standard M6x1 (7.6-8.4 Nm; 0.80-0.85 Kgm; 5.8-6.1 ft/lb)
  14. ray_ray Mini-Sponsor
    The Philippines
    No manuals came with the bikes? As long as you do not have to re-time the engine, this process is easier than most other brands I have read about ... except my 08 TXC250 :) ...
    Nice Pics!
  15. Antz Husqvarna
    Isle of Man
    Many thanks guys. I'll be checking the clearance tonight and I'll let you know how I get on.
  16. husky bom Husqvarna
    if you guys need any specks let me know i have the husky manual for the 2010 te/tc/txc 250
    hope i can help just pm me
    John Appleby likes this.
  17. Antz Husqvarna
    Isle of Man
    I carried out the valve clearance check and found them to be spot on.
    The proces is really simple, just:
    Decide on the cam you wish to check and identify the punch line adjacent to the round hole on the cam drive gear. The turn the engine over (in the normal direction of rotation) until a punch mark on the cylinder head appears in the round hole in the drive gear and alignes with the punch line . Then simply check the valve clearance.
    Repeat for the second cam.
    Hope this helps. The top end is a jewel!
    Antz
  18. krieg Husqvarna
    Matthews, NC
    Many in the past
  19. Applepie Husqvarna
    England
    TE 310 2013
    Honda VXR 750. Suzuki DR350
    Hi
    I have a 2011 Te 310 i have chacked the valve clearance .16 inlet and .24 exh so will need to change shims, Does any one have the torque figers for the cam cap bolts.
    there are 2 sizes M6 & M5
    Cheers
    Paul
  20. JasonfromMN Husqvarna
    MN
    None right now :(
    2013 Yamaha FZ6R
    I'm also interested in torq specs. Also, wouldn't there be a clearance allowance 0.**mm - 0.**mm intake and 0.**mm - 0.**mm exhaust? I cant imagine if the intake and exhaust aren't exactly 0.15mm and 0.20mm they need to be shimmed. Every engine I've ever known has a small variance.
