Steve,A friend is looking to buy new or good used 17.5 shocks.
Its for a 81/82 CR or XC.
He has none to start with at all.
Any one know where one might start looking, zip has been on ebay?
Thanks Steve
Yes 18.5 i bet, too longthanks though John!
I know another member cut and re-welded the lower shock mount on ITC's to make them suitable for 81-82. I also recall seeing a post where someone said you could purchase new shorter lower mounts to adapt the ITC's to 81-82 years. You may be able to get them direct from Ohlins. Not sure about the difference in the internals, but the single progressive spring is much better than the dual spring design.
'81-'82 shocks bolt to side of swingarm, except 420 Auto which uses older style swing arm.I think Fran has it right. The ITC shocks used on models with the center bolt swing arm need the very long eye to clear the swing arm as shocks are compressed. We can shorten the ITC's by adding a spacer inside with no problem, it would require disasembly.
Steve,
I've got a extra pair of ITC Ohlins , i think there 18" though.
Husky John
