Piston Pin Spacers
Discussion in 'Vintage/Left Kickers' started by Go_Navy, Apr 10, 2011.
  1. Go_Navy Husqvarna
    St. Louis
    I can't find the spacers for the piston pin anywhere. Are they optional?
  2. adam6402 Husqvarna
    Tulsa, OK
    None
    Not sure what you have, but sounds like a bad idea not to use them. I'm about ready to start putting my '82 XC 250 top end back together. Those spacers are each 2mm thick. The top end bearing will be free to move laterally much further without them. The OD is 27mm and the ID is 18mm. Someone on here probably has some extras or at least a source for some replascements.
  3. dumbdotdog Husqvarna
    Reno, NV
    70 360 74 125SC 74 250MAG 81 250CR
    They keep the rod centered and prevent the big end of the rod from contacting the crank counterweights. I coudnt find any for my 74 125 so I had Andy at PVP cycles machine me a couple. http://www.pvpcycles.com/
  4. Go_Navy Husqvarna
    St. Louis
    The actual name is a "Distance Ring" PN 16 10 971-01
