Plastic type (fenders & shrouds) ?
Discussion in '610/630' started by Yossarian, May 18, 2009.
  1. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    Multistrada 1200 Enduro; Tiger 800XC
    Anyone know the type of plastic used for the fenders and shrouds of the 610? I would like to know so that I can stock some plastic welding rod if these are repairable items.
    TIA,
    Y
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    That would be a good thing to know, see as how I might have to resort to fixing my cracked rear fender. That fender is backordered, so I can't get a new one.:thumbsdown:
  3. Hoopdy Husqvarna
    OZ sth east QLD
    I cracked one of the radiator shrouds on mine and took it to the local plastic repairers, who told me it was POLYPROPELENE and not repairable :confused: If anyone finds out otherwise let us know
  4. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    I am not sure if this will help much but a very talented welder friend of mine said to scrape some shavings off the plastic and light it with a lighter. If it burns completely turns to ash it is PVC, if it melts and turns waxy it is Polypropelene. He said that is how you tell what plastic rod to get.
    Later,
  5. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    The fenders have the triangle and PP, which I'm nearly certain is polypro. If it was US it would have the 5 inside the triangle but probably the Euro standard is the PP.
  6. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    Thanks!
    Polypropylene is actually repairable. You can use Plastex™ or some welding rod stock and do it.
  7. RLW Husqvarna
    Boise, Idaho
    well this was good timing.
    Couple weeks ago, front end washed out on a loose corner and I put my 510 down (for the first time of course :rolleyes: )
    Also cracked a radiator shroud. Nothing I tried held except a zip-tie at the top.......I'll have to give this a try.
