125-200cc plastics- years interchangeability - is that a word?
Discussion in '2 Stroke' started by yzrider, Feb 8, 2014.
  1. yzrider Husqvarna
    2004 cr125
    2009 yz250f 197? rickman zunpaap 125
    Ive got an 04 cr125 and liked the looks of my 05 tc much more. Im fairly sure i can bolt up 05 fenders but what about the rad shrouds or side panels?
    I like the front numberplate but putting numbers and backgrounds may look a bit silly as it has the husky logo cutout.
  2. outdoorsman166 Husqvarna
    2008 WR250/1987 430xc
    I can tell you that I once purchased 09 tc plastics for my 08 wr and nothing but the front fender would work. Ended up selling whole set back on ebay, but I did double my money :)
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    I don't think tc and wr have interchangeable plastic, maybe 09 wr plastic would work
    or in the 1st post 05 wr plastic
  4. rancher1 Husqvarna
    WA
    It will fit but you also have to change the seat and tank to make this happen.
  5. Drtrider82 Husqvarna
    Chatham, Il
    11 CR125 with WB165; 13 TC250
    You would need the 06-08 cr/wr 125 or 06-current wr250/300 seat and fuel tank to make upper and lower radiator covers work. You will have to weld a threaded post on the frame as well as change out/relocate the two rubber bushings that the tank rides on to use the newer tank. Then it will all change over. If you don't want to do that much work the 2005 two stroke rear number plates are slightly more modern looking and will fit with the new style rear fender well.
  6. Idacurt Husqvarna
    hailey,ID
    07 WB177
    Scorpa 175
    Not trying to hijack this thread but Will any newer years fit on a 07?
  7. yzrider Husqvarna
    2004 cr125
    That would be a great start, so get 05 rear fender and side numberplates. That will all bolt on? You are correct i do not want to replace the tank and have to do any welding and what not. Just was looking for any cheap and easy ways to improve it.
    Thanks alot
  8. NeoGeniX Husqvarna
    the Netherlands
    You can buy rear number plates but they won't be plug and play. They are not made for the old style seat so they would need a lot of modification to fit with the old style seat.
    Also they won't fit at all with the old style tank plastic.
    I had some newer style plastic lying around and thought about doing this but it's just going to be very ugly and wouldn't line up at all.
  9. Drtrider82 Husqvarna
    Chatham, Il
    The 05 rear plates are specific to the 05 model year and will work with older style shrouds and new style rear fender. You are correct that the new number plates will not work with old shrouds.
  10. Drtrider82 Husqvarna
    Chatham, Il
  11. HuskySam Husqvarna
    Finland
    wr 360 2000
    I have wr 125 -08 plastics, tank, seat on My wr 360 -2000. Direct bolt on, just have to change tank thread and Those rubbers under tank. Like Drtrider82 Said.
  12. Miezie666 Husqvarna
    Germany
    2x YZ 125, 1x YZ250 2005, XT600 2KF
    As Plastics are hard to find i suggest to convert a pre 2000 Bike with a 2000 onwoards plastic kit, subframe 00- (or a modded stock subframe), tank and seat, if u go for the latest plastics u ll need to weld a braket on top of the Main beam of ur frame.
    It s easier to modify the 1995 onwoards bikes than the 1992-94 as u have to cut a re-weld the tank brackets onto the frame.
    hardest part would be to modify the subframe- it needs to be narrowed so the plastics and seat will fit- otherwhise it just wont look right- the newer subframes are a Lot slimmer.
    Also on some old style radiators u ll have to build a braket to adapt the newer style plastics.
    There are a few guys over here which have done the conversion- i haven t got a detailed picture- but its worth the hassle of doing it as u ll get all plastics in all coulors easily.
    I would not suggest to convert to the 2013 WR 125 plastics as the frame, subframe are totally different- all other 2 strokes are very similar with only slight modifications to the pre 2000 bikes
  13. Daniel B Husqvarna
    Portugal
    sms 125 - WR engine and 36mm carb
    Customised Yamaha Zuma 50
    Hi all,
    I bought member Tgraca 2008 sms125 in October 2015,after he upgraded to a hypermotard SP821 and getting back on topic ,I confirm that I was able to fit the 2009-2014 CR125 side panels.http://www.ebay.co.uk/itm/252149373185?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    and the Te510 rear fender http://www.ebay.co.uk/itm/252144609073?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    Here are some photos..https://onedrive.live.com/redir?resid=1E3991BEEA5DD19C!112&authkey=!AKtEwie-pWPF0oA&ithint=folder,
