Please can someone help before i go insane!
Discussion in '610/630' started by rich74310, Sep 12, 2010.
  1. rich74310 Husqvarna
    france
    Hi,
    i have a 98 610te and it has abit of a problem.(it wont start).
    first thing i did was check the spark plug(changed for new and sparks)
    second i seviced the carb with all new bits
    and third i checked the valve timing(all good)::
    Put new fuel in it and it will not start.
    Please can someone help as im getting to the point of throwing it away
    :confused:
    Be grateful if someone had an idea
    Thanks
    Rich
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I see a lot of things you did there, but not a compression test yet?:excuseme:
  3. rich74310 Husqvarna
    france
    Hi
    i dont have a compression tester. but the kick start did hit me in the leg and bruise me if that helps
    thanks
  4. organ donor Husqvarna
    Berlin
    Is it getting fuel? Is the plug wet after unsuccessful attempts at starting? Is there an in-line fuel filter that´s maybe blocked?
  5. rich74310 Husqvarna
    france
    yep fuel is all good.its almost as if some times it sparks and sometimes not.just doesnt want to fire at all
    thanks
  6. ray_ray Mini-Sponsor
    The Philippines
    Maybe put some fuel on the plug and re-insert it and see if it will at least bruise UR leg again :)
    Try pushing it or tying it behind a truck and bump starting it ...
  7. rich74310 Husqvarna
    france
    hi guys
    have done all of the above with no luck
    just really stuck with what to do
  8. BILLF CH Sponsor
    BMP Husqvarna, Salem, OR USA
    92WXC350 /Lamson CR250/701 Vitpilen/
    Triumph900 Scrambler 1200 HD Nightst
    The flywheel magnet pack can come loose inside the flywheel on these and still spark,also make sure the choke assy on the left side of carb isnt falling off.billf
  9. carl r Husqvarna
    warwick,uk
    what bilf said.....i had exactly the same thing on my 96 610....i realigned and bonded them back in the correct place and she starts and runs well..
    plenty of threads on loose mgnets:thumbsup:
  10. TheDutchman Husqvarna
    Watsonville, CA
    I agree with this, it sounds like something coming from that side of the engine. Pop off the cover, clean it up and check your magnets!
  11. rich74310 Husqvarna
    france
    well i have found the problem.
    it was a hair line crack in the cylinder head,so now i need a newone.really gutted.
    just been quoted 1500euro for the repair. does a 610tc 98 head fit on a 610te 98 kick start model? please someone let me know as ive found one.
    Thanks for all replys guys
    cheers
    rich
  12. rancher1 Husqvarna
    WA
    Yes they should fit.
