Post fuel pump filter size?
Discussion in '4 Stroke' started by mikewindspeed, Aug 22, 2012.
  1. mikewindspeed Husqvarna
    Eden, UT
    2009 TE510
    I have not been able to find the post fuel pump filter specifications, i.e. 10 micron or?
    If anyone can help me out with that I would appreciate the input.
    Thanks, Mike
  2. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    I think all there is only speculation of the micron rating of the stock filters... I don't think they are ideal for our systems for many reasons. I believe they are 10 micron filters though... 5 micron for EFI is ideal apparently. One thing to remember is there is a very small filter at the inlet of every injector that you really realy don't want to actually have to filter out anything- because that means it will clog quicky, especially if the actual fuel filter is NOT doing its job. The injector filter's can be cleaned through a process- but I wouldn't recomemd it to the average guy.
    I am using a cross refferance of the Duralast ff3330DL that OlderHuskyRider has been using. Mine is a puralator. Here's the Fram G3606 specs (same as OHR and my filter) and MAJOR cross refferance guide at the bottom...(pick a brand) http://www.framcatalog.com/PartDetail.aspx?b=F&pn=G3606
    Here's some more posts regarding the filters
    http://www.cafehusky.com/threads/2011-te310-just-dies-and-will-not-refire.21048/
    http://www.cafehusky.com/threads/du...50-with-cheap-tricks.15347/page-4#post-203659
  3. mikewindspeed Husqvarna
    Eden, UT
    2009 TE510
    _______________________
    Thank you very much HUSKYnXJnWI, great information and it helps me out a great deal; the small filters at each injector opening I was not aware of.
    I had supspected it should be 10 microns or better since all th references I could find for post pump filters pointed that direction.
    Pointing me in the right direction for the purchase was a major bonus...again thank you very much for taking the time to help me out!
    Mike, Eden, UT
  4. HUSKYnXJnWI Husqvarna
    09TE450
    to be clear, the injector filters are at the inlet of the injector- they can be replaced but requires a special tool. there are instructions on the web to clean injectors/filters by cleaning them backwards (Spray cleaner/air compressor) and opening the injector (small 9/volt battery). Not that this is necessarily something that is prescribed at this point for bikes- but as EFI gets older I imagine we will be doing this as part of maintenance in time. I think I know of 1 guy on here CH reported to having done this. I don't think dirty injector filters has been found to be a cause to a problem as of yet. But is relevant to bring up when discussing the changing or referencing different part sources for inline filters.
  5. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    The filter I have previously used and recced is no longer what I use Here is what I will be getting and using. I will post my results.
  6. R_Little Husqvarna
    NJ
    I am going to try to "fix" the extra pump I have in my parts box.
    What is the fuel line and clamps I will need to replace the filter and where do I get them?
    Thanks!
  7. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
  8. R_Little Husqvarna
    NJ
