250-500cc power band problem
Discussion in '2 Stroke' started by phillwood, Oct 2, 2010.
  1. phillwood Husqvarna
    Australia
    hi there i have a 96 husky wr360, had a full rebuild. crank, rod, piston, every bearing in the engine replaced with new. new reeds cleaned the carby, replaced the spark plug, coil and lead.
    ok so here is the problem start in fine no problem. warm it up for about 5-10 mins, runs fine power band come on beautiful. after riding it around for about 15-20 mins the problem start to happen power band dosent come on, bottom end runs good but soon as it should come into band, nothing happens.. makes a big brrrr noise and donts want to move just satys at the same speed.. when this happens blows more smoke then normal..
    if anyone could help me out would be much appreciated..
    Cheers
  2. letitsnow Husqvarna
    mn
    FC250
    CBR600F4
    Have you tried a new spark plug?
  3. Bill502 Husqvarna
    Upstate NY
    2007 WR167 1978 CR250 1938 sw maus
    1970 Triumph T100C 1973 Honda TL125
    Maybe a Crankcase seal!
  4. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    cdi was going bad on my bro's cr250 did the same thing.
    Usually it would be fine untill 10-15mins like your saying.
    If you have a manual there may be a multi meter test for your cdi.
    Though if it were the cause, its weird that the problem just popped up after your rebuild.
  5. jo360 Husqvarna
    perth australia
    1983 exc framed wr430 engine
    ktm 520exc
    remove the hts cover and run and warm up bike as usual, once the problem occurs disconnect the linkage at the upper power valve actuating arm and wind the throttle if the bottom actuating arm moves then the problem is in the exhaust valve mechanism you can check this for free movement by physically moving it, may be binding when hot.
    other than that you will have to do the usual back tracking to nail down the fault.reeds, jetting, seals, electrical and vaccum.
    if you have a decomp head check that too.
    hope this helps.
