Power Commander FC
Discussion in 'EFI/carb' started by TheRealBuzz, Apr 4, 2016.
  1. TheRealBuzz Husqvarna
    2009 te 450
    Anyone have experience with the PowerCommanderFC
    Specifically on 08-10 TE450's but experience on any model is welcome.
    I was looking at PCv with AT and just noticed the PCfc.
    Certainly less tweak-ability but still can load different maps and edit them with android device. And if I understand correctly you should be able to overwrite the pre-loaded maps for other models with maps just for your model allowing you to easily switch between 10 different maps instead of just 2.
    Any thoughts.
  2. cgwar Husqvarna
    severn, md
    I put a DynoJet PowerCommander V on my 2009 TE450. It helped get rid of the dead spots in the throttle response. You can put it in autotune and then lock in the map.
  3. TheRealBuzz Husqvarna
    2009 te 450
    PCV with AT is for sure the ultimate setup as it would allow for easy map creations for all seasons.
    Especially useful if one was to get a Timbersled kit! :rolleyes:
  4. norma stitz Husqvarna
    SMR511
    Nunya185
    Which is exactly what I did! Except it's a mototrax kit instead. The PCV has made this bike purr
