I tried searching, but could not find what I was looking for. Has anyone installed a PC-V and Auto tune on their 08 or 09 TE610? If so, did it give more power or better driveability?
PC V and AT Yes, I put a power commander on my 09 te-610. I had it ibeated before so it was running pretty good but I still wanted MORE so I installed the PC and AT. It did give it more power but it was not a night and day difference. With the added power, gas mileaged dropped a little. I plan to add the switch so I can change between good mileage and good power. The only problem that I had was that over time the AT kept trying to lean it out at 2% and 5% throttle position so I ended up inputting all zeros in those 2 colums and that fixed it.
I assume you have the Leo Vince. With the PC5 and AT installed, do you keep the reisstor plugged into the factory harness?
Yes, they even give you the resistor plug when you get the PC5 and AT although I already had one installed from doing the "power up" before buying the PC5. And yes, I have the LV installed also.
