Slowflyer
What is it with vehicle manufacturers? Are they that mean that they can't put a couple of extra switched circuits in their fuse block?
The high end after market ones are great but expensive, there appears to be nothing in the middle and the low end stuff is rubbish and not suitable for bouncing around under the seat. So I bit the bullet and installed a small active bus and an earth bus. The active bus is housed in a robust plastic container and is powered through a fused relay. The earth bus is screwed to the plastic box lid. The relay is good for 30 amps, my wiring is 15 amp and the fuse is currently 15 amps but I will see if I can get away with 10. The active bus is just that; a bus, and not a fuse block. I might use in line mini blade fuses for the accessories but probably not given my heated hand grips are less than 5 and I only intend to add a dual USB charger (Max three amps) and maybe, some led lights.
Here is a picture. By the way the coiled blue wire is the trigger for the relay which I intend to take from the capped plug above the head on the left side. Still waiting for the BMW plug to come from Munich****************************************
