Power Dynamo retrofit
Discussion in 'Vintage/Left Kickers' started by Darrel78, Aug 19, 2016.
  1. Darrel78 Husqvarna
    Central Arkansas
    87 WR430
    I recently lost all the sparks out of my mini 6 on my '87 WR430. Checked in to repairs/replacement and ended up at Power Dynamo's website. Ordered their kit 71 25 799, the A/C unit for $313 (all up price including a flywheel puller and shipping to USA). It took all of an hour to install and works great! I didn't have starting issue before and my power budget for lights was inline with the output of the motoplat so I can't say I see much differences between the two systems. My lights seem a bit brighter but I don't ride after dark much so I can't say for sure. The bike is still a one or two kick affair and doesn't offer to kickback. Timing is set to ~ 1.5mm BTDC. Seems a great price for a new direct replacement ignition. 10 days from order to finished install.
  2. grouty Auto Lover ...
    South West UK
    78 390WR, 78 390 AMX, 500 Humph
    works 73 CCM 520, another 73 CCM520
    I totally agree with you. Mine arrived from Germany within 7 days. I fitted it to my 390 Auto a few months ago. Fitted within about an hour (except for the wiring for the lights). Timing set to 1.9mm BTDC. Starts perfectly and runs superb. I opted for the DC kit as we have to have a working horn in the UK to be road legal and the DC horns take less current than an AC one. The regulator / rectifier was a bit too bulky to go under the tank, so I mounted it above the airbox. I had a photographer complain to me at the weekend that my headlight was too bright and caused issues with him taking a picture ......
    I have another one to fit to my 390WR 6 speed when I can get around to it.
    Darrel78 likes this.
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    sounds like a good option. other than them being old, the motoplats only real weakness is the lighting output...which sucks.
  4. RUF Husqvarna
    SACRAMENTO
    510 air, 400WR 85, 430WR 87
    BMW R80GS, GILERA 175RC 1972........
    Darren.
    TIMING IS SET TO ABOUY 1,5 MM BTDC
    Its dangerous to me, the motor can overheat under 1.9 mm.....
    Just be carefull please.
  5. justintendo klotz super techniplate junkie
    really? have always run my big bore swedes with backed off timing 1.5-2.0 btdc...no problems.
    you are saying he needs to advance the timing to cool the engine?
    lots of us here retard the timing a bit to help with easier starting and less kickback.
  6. Darrel78 Husqvarna
    Central Arkansas
    87 WR430
    I'll keep an eye on the coolant; this scooter hasn't offered to overheat as yet. I find it doesn't kick back at this setting.
  7. RUF Husqvarna
    SACRAMENTO
  8. Darrel78 Husqvarna
    Central Arkansas
    87 WR430
    Changed the H4 bulb out for a brighter halogen unit and rode this evening. Amazing how much easier it is to ride at night when you can actually see. Super bright! Easy starter hot or cold. Life is good!
    justintendo likes this.
  9. Simon Mathewson Husqvarna
    Tweed Heads Australia
    1982 420 AE
    Yamaha IT 200 , KTM 350 EXCF
    Grouty,
    I have a 1982 420 AE that is nearly impossible to start cold - although it will start hot.
    I tried a Power Dynamo ignition and then an Electrex Works ignition.
    The bike has a NOS barrel and new pistion which makes it a 390 now.
    I have replaced the ignition side crankshaft seal
    I have not split the cases yet, so I'm not sure what the drive side crank seal is like.
    I have also replaced the carburetor with a new one and changed jetting etc.
    I'm interested in your comment that your 390 starts perfectly.
    Is it possible that I could call you and talk about this?
    Simon.
  10. grouty Auto Lover ...
    South West UK
    Yeah, a call is no problem. Just remember that I'm in the UK :) I will PM my number to you.
    Out of interest, what timing did you set it to ? Carb ? Is it a Mikuni ? (I hate them , but they work fine). Have you done a leak down test ?
  11. Simon Mathewson Husqvarna
    1982 420 AE
    Ian,
    Got you email - many thanks.
    I'll you at civilized hour in you evening.
    Timing is 1.8mm BTDC - Carb is Mikuni VM38
    Jetting - Pilot 45
    _
  12. Simon Mathewson Husqvarna
    1982 420 AE
  13. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    hows your compression? also check your choke circuit. try tipping the bike over on one side to prime it. float level can be important with cold starts.
    your fuel tap isn't leaking and filling your engine with fuel (like mine does). If it doesn't light up in 2 - 4 kicks with choke, I turn it off and go full throttle andkick like mad. 10 - 15 kicks shes away but sprays fuel out the exhaust.
