250-500cc Power issues wr300...
Discussion in '2 Stroke' started by DON SIMMS, Jun 16, 2014.
  1. DON SIMMS Husqvarna
    Voorhees nj
    2004 TC 450 2011 WR 300
    Had the bike out for its first long ride after picking it up a week ago. Seemed to run fine on the low end. After getting on the fire roads with my ridding buddies i found it falling off at the top of every gear(buddy with a 13 txc 310 was pulling on me). I've never owned a 300 and haven't had a 2 stroke in the garage in 10 years. Is this normal? The guy i picked it up from seemed super knowledgable about the bike and its setup. Said hes running a 420 main jet in the carb and to run it at 40:1. Any input would be awesome guys
  2. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    somethings not right. I can barely hold on to mine when i open it up. Thing pulls to the moon.. I assume compression is good? Got it jetted so you got the perfect color with spark plug? Which carb? Bike used or new?
  3. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Mine has good power all the way up. JD kitted, 440 main jet. But even before the carb was kitted, it had fairly good power characteristics with the stock 420 main jet.
  4. shrubitup Husqvarna
    Seattle WA
    verify power valve functions at top end throttle openings. remove PV cover and visually verify that it's opening.
  5. DON SIMMS Husqvarna
    Voorhees nj
    Has the stock carb on it. I haven't checked spark but it starts and runs great on the low end so i didn't think it was an issue
  6. DON SIMMS Husqvarna
    Voorhees nj
    How do I do that? Can it be checked on a stand running in gear?
  7. shrubitup Husqvarna
    Seattle WA
    yes on stand but in neutral with PV cover removed.
  8. justpinit Husqvarna
    Maryland
    2012 wr 300
    93 kx 125 with a kdx 200 engine.
    There are stops that limit how far the pv open, take a look at that as well. Maybe the po wanted to tame it a little. I also have the 420 main jet, and my 300 pulls alll the way through. I'm at sea level.
  9. DON SIMMS Husqvarna
    Voorhees nj
    Does anyone have pics of what the power valve should look like when set correctly?
  10. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    $ Float level too low, needs a bigger main jet, air cleaner over oiled or silencer needs re-packing .
    $$ Cracked inlet boot, chipped reeds.
    $$$ Ignition
    $$$$ Compression
