Power Source for a GPS
Discussion in 'TR650' started by lwoodring, Mar 2, 2014.
  1. lwoodring Husqvarna
    TR650
    BMW R1200GS
    Been searching on a 2013 650 Terra for a power source for a Garmin Zumo 550. Found a spare BMW-like plug in the headlight area. Bought a BMW plug and it fits - tested and found a hot wire (number 02 on the BMW yellow wire).
    Not sure if I should plug into it or not. When I did plug the GPS into it, the GPS did not turn off when the power was turned off. The plug tested as "switched" with an meter = power on when switch is on; power off when switch is off. But the Zumo stayed on.
    Any suggestions? The other empty plug I found under the gas tank just above the head appears to be a Lambda sensor in the shop guide.
    Any suggestions?
    Thanks
    Lee
  2. Baddrapp Husqvarna
    Yucca Valley
    TR650
    The Garmin will not shut down, it started using it's battery. Which plug did you buy? Do you have the part number handy? I heard it is a 5 volt plug for accessories. I want to plug into it for an usb outlet.
    snail_72 likes this.
  3. lwoodring Husqvarna
    TR650
    BMW R1200GS
    I went to the BMW shop where I bought the Terra and purchased two (one for a friend) BMW power plugs for about $15 each. It says on the bag: 3204460313-0085. Repair plug 2-pin. Dealer order number 8747. On the top of the bag it says 8330 0402 344 BMW group. Standard part. Fits all of the single plug.
    On my previous BMWs, Ducatis and such - when the switch was turned off, the GPS would give a message saying it was powering down and then would. Not now.
    Nordland likes this.
  4. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
    Check in the Garmin settings to make sure that the "auto power off when ignition is turned off" setting is selected. It's also possible that this setting will only work when the GPS is on 12V power not 5v ?
  5. lwoodring Husqvarna
    TR650
    BMW R1200GS
    I appreciate the settings suggestion. I did not see that option when I looked, but will ask Garmin support. The power that I connected to was 12V. The 5V I tried did the same thing. I looked at a new power cord from Garmin and it came with a 3V fuze - so i would imagine that the 5V should have worked. Thanks
  6. lwoodring Husqvarna
    TR650
    BMW R1200GS
    FYI - I checked with Garmin technical support and there are no real settings in the Zumo 550 for auto power. If the device has stopped receiving power, it will ask the user if he/she wants to continue on battery or shut down.
  7. lwoodring Husqvarna
    TR650
    BMW R1200GS
    Found a decent power source. Tried the BMW type plugs and they fit several places, but were not wired correctly/pinned correctly to supply GPS power.
    Pulled the front light and tied into the small "peanut" light bulb that sits separately above the headlight. Gave appropriate, switched power and was relatively easy to access. The empty space around the headlight components provided great storage space to tuck in wiring.:)
