Power Up Install on on My -510
Discussion in 'EFI/carb' started by proeasy, Mar 26, 2010.
  1. proeasy Husqvarna
    SE Michigan
    TE-630, TE-510
    R1100 RT, XR-400R
    Just put the PU kit on my 08 -TE-510. Took it for a ride on a cold night last night (about 35 deg F) The bike stalled a lot when decelerating.
    Have never had the ECU "updated"
    What should be next steps
    Appreciate the help
    Paul
  2. jlk_250 Husqvarna
    Minneapolis, MN
    It stalled when braking or just from rolling off the gas?
    If the former, check for the slipping fuel pump problem. If it stalls from just rolling off the gas, how many miles are on it? Finish break-in if very low miles, then worry if it still does it. Otherwise, hopefully someone else can suggest something. Send VIN to Coffee so he can tell you which version ECU your bike has?
  3. proeasy Husqvarna
    SE Michigan
    TE-630, TE-510
    R1100 RT, XR-400R
    On the short ride in the cold last night it stalled at least 5 times on a 5-10 mile ride when decelerating/closed throttle. I sent Coffere my VIN.
    If it runs like this all the time, will have to hook up the O2 sensor.
    Appreciate any help as it is warming up in michigan.
  4. AndrewS Husqvarna
    Niagara Region, Ontario, Canada
    2015 FE350s 2013 TE310R
    2009 TE250 (sold)
    Everything I've read indicates that you need to setup your ECU with iBeat after installing the PU kit.
  5. Coffee CH Owner
    1. I would contact Halls and (probably) send them the ecu for an update
    2. I would get access to iBeat
    3. I would get a PC V & Autotune - possibly far more important than iBeat based on my experiments.
    I would do #1 regardless. Seriously. Even if you plan on simply putting the O2 sensor back in.
  6. Fast1 Husqvarna
    Minneapolis, MN
    Did you have ethynol fuel in your tank all winter for storage?
    Did you run it this spring before switching to the power up kit and did it run well?
    What rpm do you have the engine idling at?
  7. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    1. :thumbsup:
  8. simonetti Husqvarna
    Slovenia
    TE 510
    Does anyone know what the thread/bolt size is on the lambda/O2 sensor block-off bolt?
    Thanks.:)
  9. seymore Husqvarna
    Boise, ID
    The O2 sensor thread is M18x1.5.
    You should be able to find a plug at an performance automotive store. It will probably made of steel, so coat the threads with anti-seize to keep it from getting rusted and then stuck.
    The bike is probably running very rich unless you adjust the FB1 value. After riding for awhile, look at the O2 sensor plug to see if it has a heavy coating of carbon. The ECU needs the O2 sensor installed and operating to make adjustments to FB1. Once the adjustment is made the O2 sensor can be removed.
  10. proeasy Husqvarna
    SE Michigan
    TE-630, TE-510
    R1100 RT, XR-400R
    Problem Solved
    Chalk this one up to operator error:
    1. Fuel was low after sittng all winter:
    A. Took gas tank off and found two problems.
    1a. Fuel pump had slid out of position. Used Zip Tie lengthwise to
    secure. I hear this can exacerbate a low fuel condition when it
    comes looose
    1b. The orange wire on the fuel level indicator broke off where
    soldered to the level sensor.
    Long story short, did not know I was low on fuel and during decel all the fuel rushed to the front of the tank.
    Thanks for all the help
    Paul
