250-500cc Power valves size
Discussion in '2 Stroke' started by rockdancer, Jun 9, 2014.
  1. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    I assume if I was wanting to go to 250 cylinder from a 300 - Id need new - longer power valves. Correct?
  2. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    Why would you want to go to a 250 cylinder from a 300?
  3. rockdancer Husqvarna
    Quicker response , more revvy , easier to ride on the pipe ?.
    Not sure really but like 250 power curve
  4. ohmygewd Husqvarna
    Aprilia RSV1000
    LoL...if an '00 250 cylinder fits the 300 l'd swap ya!!
  5. msmith345 Husqvarna
    Shawnee, KS
    '12 WR250, '92 360, '80 390
    '72 Yamaha R5, '17 SV650
    It does. Bolts right up.
    I went from a 300 to a 250, because I trashed the 300 jug, head, and PV. I picked up a slightly used 250 setup for a helluva deal, so I went with it. Thinking it may take some of the edge off and allow me to ride longer with less fatigue. It's definitely a different power characteristic. One I don't particularly care for. It reminds me of riding my ol' KTM 200 too much. Running it hard on the pipe most of the time. Fun in the open, not as much in the tight where lugging would keep the wheel spin in check.
  6. rockdancer Husqvarna
    my original question still remains though - do you need to use the 250 power valves? I assume so - if they are the same sort of design as 125 .
    I bought a 250 cylinder off ebay cheap but no power valves - it was also pick up only so it may not be happening anyway
  7. ohmygewd Husqvarna
    Aprilia RSV1000
    Rockdancer, looking at the parts catalogue for a 2010 WR250/300, the actual valves are different going by part numbers - by how much, maybe give Stefan a call at R&D Husky?
    rockdancer likes this.
  8. rockdancer Husqvarna
    thanks a lot OMG - it looks like its shaped to bore so will need to be changed - or will not give as good down low response I guess
  9. ohmygewd Husqvarna
    Aprilia RSV1000
    I guess you'll play with the power valve height, jetting to get you a better response possibly porting mods. If you want to 'rev' faster then you may have to lighten the flywheel but then you'll sacrifice some low down torque.
    Dunno mate...if it was me, l'd look for a complete jug from a 250, unless you can track down powervalves from the states?
  10. msmith345 Husqvarna
    Shawnee, KS
    Yep, definitely need the right power valve for the cylinder. That's the main reason I went with the 250 I found. The main piece (#11) got a chunk taken out of it by a piece of the piston when it let go.
  11. wait4me Husqvarna
    Orange County, CA
    11 WR300
    85 YZ490 "Ol Bessy"
    I'd look into maybe porting and a pipe and keep the 300. Just my $.02
  12. rockdancer Husqvarna
    Looks like I got the 250 cylinder and head and near new piston - it was cheap so its insurance really . May not fit it up.
    The guy selling it got an Eric Gore 265 kit for his -
    While we are talking about it - Anyone have any 250 power valves and booster valve theyd sell ? :o
    Thanks guys
