pre fuel injected husky and force rad guards !!! look in !
Discussion in '4 Stroke' started by rabskyline, Dec 22, 2009.
  1. rabskyline Husqvarna
    Sunshine Coast,Queenslander !!
    2014 te250r
    Yer maw !
    i was having a general poke about my bike and checking it as i do... i happened to remove my tank to align my side panels that go onto the rad sides...
    upon looking at the underside/front of the tank i noticed some marks/light gouges and immediately looked for the culprit that was going to cost me a tank and problems if happened in the trails ! ... so, the top mount of the force rad guards has a pointed square edge that was sticking into the tanks and for sure would have punctured it if it took a hit in rad area...
    so i got the grinder out and took the edges off on a 45 deg angle....both sides.. theres now a couple of millimetres space just in case and is now flat instead of a triangular edge thast will pierce the tank...
    so check your tank and that area ....also look for rubbing marks where the top rad hoses may also poke in to the tank too if screw head is tilted towards the tank... worth a look to save yourself grief !
  2. J D Husqvarna
    Sydney, Australia
    You should let them know at Force as well. Assuming you haven't already.
    Cheers
  3. rabskyline Husqvarna
    2014 te250r
    Yer maw !
    i havent... but i will now , thanks for the idea !
