125-200cc Premix ratio for 2013 WR125
Discussion in '2 Stroke' started by GoodLookinPete, Jun 12, 2013.
  1. GoodLookinPete Husqvarna
    WR125
    G'Day troops, I am using my 2013 WR125 mainly for trail riding, I like to explore tight tracks and very rarely fully open it up, mostly hanging aroung at less that half throttle. I also do a bit of on road riding, but very little of that.
    A mechanic told me I should be running my premix at 50:1
    Any thoughts on this?
  2. Blakelpd5 Husqvarna
    Tigard, OR
    09 WRWB165
    You will find guys running everything from 32:1 to 50:1.
    I personally run 40:1. I'd rather over-oil, than under oil, but I think you will be fine at 50:1
  3. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    You should be Okay at 50:1 for the kind of riding you are talking about. For more aggressive riding I'd use a minimum of 40:1 in a 125.
  4. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    I run 50:1 no problems ever
  5. huskybear Husqvarna
    B.C. Canada
    I use 32:1 in 125's, 40:1 in 250-300's and 50:1 in the big bores. Using good fuel(non-ethanol) is just as important as using good oil.:cheers:
  6. GoodLookinPete Husqvarna
    WR125
    Thanks for the replies troops, I might give the 50:1 a go, I'll be using the fully synthetic Motorex oil so I should have a little better protection.
  7. MMMOTORCYCLE Husqvarna
    I ran 25:1 for the first tank when new per the manual. Ran 32:1 since and its spooging big time. Plug is black and wet. Gonna bump up to 40:1 and see how that works.
  8. 2premo Husqvarna
    Northern NV
    if your plug is black check your jetting
  9. huskybear Husqvarna
    B.C. Canada
    Pick a ratio and jet to it,altering your pre-mix ratio to try and compensate for poor jetting is not a good idea. Going from 32:1 to 40:1 is actually making things richer by a very small amount (less oil,more fuel)
  10. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    I've always ran 32:1 in my 125's.
    I figure running wfo down logging roads to throttle chop is the most likely way to seize a 2 stroke. Plus they're not really lubed all that effectively.
    I'm sure 40:1 wouldn't be much of a difference, but 50:1 makes me nervous for some reason.
  11. 2premo Husqvarna
    Northern NV
    don't be nervous, worry causes wrinkles
    the manufacturers and oil companies have spent money on this
    I got 50:1 from a shop that was doing dyno work at 100:1 and tore down for inspections and found it was Ok
    I decided on 50:1 as a decent stopping point as I was also not completely sold even with the proof
  12. Blakelpd5 Husqvarna
    Tigard, OR
    09 WRWB165
    100:1 on what bike?
  13. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    I have a friend who has used Opti at 100-1 for many years in his woods bikes and swears by it. I race with him sometimes and he doesn't have any problems that I've seen. I wanted to try it, so I ran it in my KDX for two seasons at 60-1 (that's as daring as I would get), and my chainsaw at 75-1 for the last 3. The chainsaw has never run as well as it does with that oil. Nonetheless, mix at 32-1 for my MX bikes, with Motul 800, which recommends a 50-1 mix ratio.
    I'm so confused :excuseme:
  14. 2premo Husqvarna
    Northern NV
    Husky and KTM dealer so both Eric's in Pasadena, sadly he just closed up shop
  15. lankydoug Husqvarna
    MO
    WR
    TM 300en
    100:1 is commonly used on trials bikes but they don't see sustained wide open throttle. I wouldn't try it in the sand dunes or the open desert. I use VP110 fuel with Ammsoil @ 40:1 on all my 2t engines including trials bikes, weed eaters and chainsaws. Poor quality fuel causes a lot of failures that are blamed on jetting and mix oil. The failure of priming bulbs, "O" rings and other similar parts that harden or shrink and fail is pretty much non existent when you use good fuel.
    K.Forte' and huskybear like this.
  16. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    i got a buddy that runs 80;1 in his gasgas 300txt pro & loves it & he rides hard &a lot
  17. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    I've run Amsoil synthetic in a Husqvarna chain saw mixed so heavy that oil was dripping out of the muffler and never fouled a plug. If you can get Amsoil Interceptor where you are, I'd run it at 40:1 and not give it another thought.
    JAM, huskybear and lankydoug like this.
