Primary transmission drive gear disassembly
Discussion in '4 Stroke' started by ray_ray, Feb 21, 2012.
  1. ray_ray Mini-Sponsor
    The Philippines
    Can anyone verify what threads are on the end of this shaft that holds on this gear? The manual seems to imply it has left handed threads but the wording is a little off ...
    Also, any tips for holding the shaft in place so the nut can be loosened? I don't quite understand the aluminum shim method mentioned below ....
  2. 7point62 Husqvarna
    Southwest England
    2004 TE450
    2001 Kawasaki TR250
    I can't verify for the x-lites, but I can confirm that the Cagive twin cams are a left-hand thread.
  3. Freaky Husqvarna
    Kidderminster Worcestershire UK
    2010 TE250 x-lite Race ECU/Injector
    My Husaberg is a left hand thread too, the aluminium shim they refer to is basically to jam the gears to prevent the crank rotating when you undo the nut, copper will do too, basically any soft metal so as to not damage the gears. I use an impact driver to get the nut off but a socket with a decent bar and lump hammer will crack it, you may need a few people to hold the motor still whilst attempting this. Once the nut is off you will more than likely need a gear puller, either two or three legged, to prize the gear off the shaft, if you don't have one you may be able to apply heat and carefully tease it off but the puller is by far the best way, you can do a lot of damage with drifts and pry bars!! (been there!)
    Word of advice, apply thread lock to the nut on reassembly, I've seen these nuts come lose and do serious damage.
  4. ray_ray Mini-Sponsor
    The Philippines
    Thanks and any known method for holding the crank so the extremely tight nut can be loosen?
  5. ray_ray Mini-Sponsor
    The Philippines
    Ok and thanks ... I actually set the engine back in the frame to hold it in place ... Tomorrow, I get a cheater bar for the end of the racket... And I have a gear puller ...
  6. 7point62 Husqvarna
    Southwest England
    2004 TE450
    2001 Kawasaki TR250
    Yeah, if you don't have a gear jammer then a piece of aluminium strip (or a soft copper coin) will do the trick. I don't remember needing a puller to get my primary gear off - i think it just slid off (it was a long time ago though!)
  7. waserman Husqvarna
    Delaware,USA
    09 TE510
    BMW KTM Honda
    I've always used a penny (USA coin) in between the gears but I'm sure any soft metal that won't damage the gears will suffice.
  8. Slowpoke Husqvarna
    Southern Ontario
    Yep, any soft metal, or even a piece of wood or plastic will do as well.
  9. Planepower Husqvarna
    Edmonton, Alberta
    2007 TC 250/ 450 6spd, 2007 SMR 530
    Ducat 1198S, SV1000, CBR125, DRZ125
    Definetly LH threads! And its tight! An impact gun will be needed, i also used my propane torch to localize heat and spin it off.
  10. ray_ray Mini-Sponsor
    The Philippines
    Seems simple enough but on first attempt, that big gear behind the nut free wheels(gears locked on the starting mechanism, crank still turns) on the crank when turning the nut ... The crank can be locked from turning but in the opposite direction only...
    As a re-cap ..
    The nut needs to be turned clockwise to be removed, correct? What am I missing here on jamming this crank shaft?
    I can rotate(spin) the big gear (the one behind the nut and against the engine case) counter-clockwise with my fingers while holding the shaft in a fixed location...
    My current view ...
  11. 7point62 Husqvarna
    Southwest England
    2004 TE450
    2001 Kawasaki TR250
    Put the clutch basket back on!
    Seriously, the jammer goes between the teeth where the primary drive gear meshes with the big gear on the clutch basket. You don't need to reassemble the whole clutch - just slip the basket back on. And yeah, clockwise is good.
    I forgot just how much they squeezed in there. :)
  12. ray_ray Mini-Sponsor
    The Philippines
    lol ... thanks ... you can tell i'm just an educated idiot reading and following the manual ... But after removing all these parts and staring at it a few days, it does not look quite so complex ....
    This statement makes no sense to me either... What am I marking and for what reason?
    Remove the driving gear and the free-wheel (mark the reassembly direction), the
    free-wheel gear, the needle bearing, the washer and the spacer.
  13. ray_ray Mini-Sponsor
    The Philippines
    Got it split .. looks perfect to me in there ... mains? ..zer0 slack ... Some slack in the rod ...
    I'll post some pics on another thread ...
    Thanks!
  14. FredrikH Husqvarna
    TE 250 -06
    After loosening the nut counterclockwise, how did you remove the firat gear? I need to change the starter clutch behind it...
