Found this while working on a Maico . The loose end was plumbed into the fuel line using a t connection . It appears that the primer will push raw premix into the intake on the crank side of the reed cage to aid in starting . The Maico in question is a 1994 . Has anyone seen this before ? Was this a kit available or just someone’s idea to help them start this bike ?
its a primer from snowmobile. looks lke custom unit to aid in starting that 500/620/700 ? not sure what model you have there.
That was on a 1994 Maico 440 one of the blue Maico’s . Thank you for the reply wrx . Good to know where it came from and a direction to get parts if needed .
