125-200cc Pros and cons of a Revloc Dyna Ring for a WR144 woods riding?
Discussion in '2 Stroke' started by homespun1, Apr 6, 2015.
  1. homespun1 Husqvarna
    Considering installing a Dyna Ring on a nice WR144 that I just purchased. I am a intermediate woods rider and really enjoyed a Rekluse Pro that I had on a KTM 400. What are the pros and cons of this auto clutch and any suggestions on install would be greatly appreciated.
    Thanks in advance.
  2. Motosportz CH Sponsor
    did you find one use? Rev-loc is not longer around I believe.
  3. homespun1 Husqvarna
    I have a used one from the previous owner.
  4. Motosportz CH Sponsor
    I ran one and thought it slipped to much for my liking.
  5. Phaeton Husqvarna
    Bend, Oregon
    2007 wr 250
    2011 GASGAS EC 300 2007 KTM 200 XC
    Works great in the WR250.
    Kelly sounds like it needed adjustment.
    Motosportz likes this.
  6. Motosportz CH Sponsor
    yeah I adjusted it just did not care for it on a 125 bike. Took to much bottom off it.
    TROFFER88 likes this.
  7. homespun1 Husqvarna
    Any tips on the install?
  8. Phaeton Husqvarna
    Bend, Oregon
    2007 wr 250
    Run it and see how it goes. The clutch pull was really hard in the 250 and it was at the end of adjustment in the cable so I shimmed the rod inside the housing and it made a big difference in the clutch pull.
  9. slo rider Husqvarna
    WA
    2009 WB165
    2007 YZ250
    I liked the Rekluse in my 250 so I tried a Revloc in my 165 and had the same experience as Kelly. The Revloc didn't have the same positive engagement feel as the Rekluse, so it seemed to always be slipping a little bit. I messed with the adjustment and couldn't get a satisfactory result so it only lasted one ride before I took it out.
  10. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    I won a Revloc for a 125 on ebay and spent a whole day fiddling with it all to no avail, I just thought it was the 165 making to much power for it to handle but from reading the above posts these things DO slip a lot.
    For sale one Revloc only done a days testing :lol:
    jman2-stroke likes this.
  11. Phaeton Husqvarna
    Bend, Oregon
    2007 wr 250
    Maybe so I know they have issues with that style auto clutch on the KTM 200's
  12. Xcuvator Husqvarna
    Scholls Oregon
    yes
    The problem with that style of auto clutch is that you loose one extra plate to make room for the fat plate that is the clutch.
    I had the same slipping/adjustment issues that others have mentioned with the Revloc on my 165.
    I switched to an EFM clutch and never looked back.
    Norman Foley likes this.
  13. homespun1 Husqvarna
    Thanks for all of the responses guys. It sounds like slippage is common thread with most of the installations. Would slippage be decreased in my 144 vs the 165 bikes? Anybody like the Dynamic Ring in there144?i
  14. Chef Husqvarna
    Ontario, Canada
    08 Cr165, 09 Wr165
    01 Husaberg FE650, 07 BMW 650 Dakar
    I have a dyna ring in a 125 and a rekluse in a 144. I run a lhrb on both so I don't have a clutch to fan. I don't seem to have trouble with slipping. I also don't feel much difference between the dyna and the rekluse. I race the 144 in b class and I feel the setup has helped me get to the top of my class. I don't even consider try to be fast riding a bike in the woods without an auto clutch and a lhrb.
  15. homespun1 Husqvarna
    Well I installed the Revloc today and I just can't seem to get it dialed in. It seems like I need to adjust (shorten) the throttle cable but if that happens I will run out of room at the bottom of the clutch assembly when engaging the clutch if that makes sense?. I am considering placing a larger diameter washer to increase the gap and try to get the bike to stay still at idle as opposed to moving forward when engaging 1st gear. I was also considering the clutch tightener set on the right side of the frame but feel once again that it will not be able to pull the clutch all the way as it will stop 3/4 of the way throw its throw. I have adjusted the clutch at the handlebar about as far as it can go.
  16. homespun1 Husqvarna
    The extra washer did it! I really am enjoying this thing. Cant wait to take it out. I think my gap was off from the start.
  17. puggi Husqvarna
    Utah
    I'd like to try the Dyna Ring on a WR125. Anyone interested in selling?
  18. Phaeton Husqvarna
    Bend, Oregon
    2007 wr 250
    I was going to say add a washer but it looks like you figured it out.
  19. homespun1 Husqvarna
    Phaeton, would you describe how you corrected the clutch pull by shimming the rod inside the housing? I would like to make the clutch pull a bit easier also...
  20. Phaeton Husqvarna
    Bend, Oregon
    2007 wr 250
    You did that by adding the washer. You can try to lengthen the clutch arm on the motor. Or there are different clutch perches that may help. We just got use to the heavier pull but adding the washer did help.
