pulled out the 390 from winter storage and wont run
Discussion in 'Vintage/Left Kickers' started by patgas, Mar 14, 2011.
  1. patgas Husqvarna
    dolgellau/ wales
    such a nice day today so i decided to pull the 79 or 390 and give her a run,after about 5 kicks she ran wow brill and then i stalled her,and spent the next hour trying to start her and she wouldnt go ending up knackering the kick start return spring (i think) gutted pulled plug and wet but spark seems faint anychecks i can do or any ideas guys.
  2. Murph Husqvarna
    UK
    Did you have fresh fuel or was it from last year? The fact it started indicates that the ignition is ok, but a new plug might also be worth trying. But I would suspect old fuel first if you hadn't mixed up any fresh.
  3. patgas Husqvarna
    dolgellau/ wales
    yep fresh fuel and she did run for while when i put her back together again will drain fuel and strip carb and clean and try her again,going to check coil m/magnto ect just to make sure.
