Pulling more power from TE511
Discussion in '4 Stroke' started by R. Stephen, Jun 25, 2012.
  1. R. Stephen Husqvarna
    I have a TE511 with a FMF pipe and JD tuner I'll be taking it to the dyno soon, any other suggestion to get more out of it? Open up the air box? Its only use is Supermoto tracks so I'm open for suggestions. IMG_3409 (Large).JPG
    58Driver likes this.
  2. Londin Husqvarna
    Denmark
    SMR 449 MY11
    Ducati 848 and Hypermotard 1100
    Got a SMR 449 with same question! Looking at the airbox, i'll presume you could change the andle or open up the intake to get more air. Been looking for an high-flow airfilter but havent found any yet!
    Is that a wheelie bar you got on the back??
  3. CrankN Husqvarna
    Australia
    TE610
    ***Hmmm, wonder if there is a bigger bore kit available****
  4. spud1968 Husqvarna
    London, England
    What ive heard about the 449 is fit a 12hole injector, power commander derestrict the tc449 exhaaust fitting a power bomb, derestrict the airbox, high comp piston, hot cams........or buy a tc449 and start with that bike. The tc449 is raced sm in the uk with 50mm marzzochi forks. There is a bike on fleebay up for sale contact the seller he runs a sm race team here in the uk.
  5. Motosportz CH Sponsor
    Good looking bike. Why do you run the levers so low?
  6. eastrider Husqvarna
    love the look of that bike , nice seat
  7. cbreakin Husqvarna
    SoCal
    2009 TE510
    Looks like he's running a "rear hand brake" most likely below his clutch. I would say this bike is very much setup for stunting.
  8. R. Stephen Husqvarna
    yeah I do both stunting and taking the track riding a bit more serious this season, natural progression I guess. Just getting whooped up on the track by the bigger bikes, I can catch um in the corner but they out HP me in the straights. yes that lever is a rear handbrake
  9. huskysmr449 Husqvarna
    smr449
    Nice bike buddy does the power commander derestrict the smr or would u have to get another chip ?
  10. Turza57 Husqvarna
    SMR 511
    Where did you get that wheelie bar and how did you mount it? I whould want to get one for my smr but i can't find them anywhere
  11. MFGamesta Husqvarna
    SoCal
    TE449
    S1000R, Beta 500 RR-S
    If you want to open the air box you can get the TXC airbox or just cut similar holes in yours and use some aluminum screening attached with safety wire.
    I'm guessing you at least have Race Map II enabled or Race Map III. You can do II with a paper clip. Both make a noticeable difference.
  12. donjohnson Husqvarna
    New Zealand
    SMR511
    Love the seat, where's it from? Thanks.
