Putting some -LIGHT on the Subject---
Discussion in '610/630' started by Blazes, May 24, 2014.
  1. Blazes Husqvarna
    South Africa
    Eddie Seel 634SMR works Replica -
    Aprilla Dosodoro 2X 2009 610
    Its been a while that I have been thinking of a fairly inexpensive way to fit decent light to A husky 610 TE without re designing the whole front --
    I have been working on a Carbon mold that just clips onto the existing headlight shroud -
    This is what I eventually did for a friend and have made some extra sets for my own two 610TE's
    The Mold that clips on using a bit of silicone to fix it --
    The bracket using aluminum bent and screwed into the existing threaded holes with washers in the triple clamp and fitting two LED lights onto it DSC06153s.JPG
    From the Front ---
    Fitted in position --
    CODYs, Big Timmy and Fast1 like this.
  2. Blazes Husqvarna
    South Africa
    Another Angle --
    From the back --
    Before they switched on
  3. Blazes Husqvarna
    South Africa
    Dim Lights ---
    That is with one light on --two makes it just a bit sharper --
    The beauty about fitting the LED's to the bike firstly is they hardly draw any power and secondly they do not jump like a cat on a hot tin roof when you riding like the stock light --or lack of light does ----
    Easy to do and works well -- I would just use a less stronger LED on mine when I fit them --
    Could blind oncoming traffic --:banana:
  4. Clete Husqvarna
    Tigard, OR
    '01 CR/WR 250, '13 650 Terra
    '06 Suzuki SV650 (gone)
    look like advmonster M60's?
  5. Borgschulze Husqvarna
    2007 TE 610
    2004 Yamaha WR450
    Please sell me one of those!
  6. Muddy Waters Husqvarna
    On the islands
    Man that headlight mask is beautiful Blazes, show us more :cool:
  7. Blazes Husqvarna
    South Africa
    Thank's MW ---:)
  8. Blazes Husqvarna
    South Africa
    I would gladly make you one --but I am sure the cost to get it to you will cost a whack --:(
  9. Oklahoma Rider Husqvarna
    2006 te 610
    What lights did you put in that Blazes?
