Puzzling issue on oil capacity RM125, any ideas ?
Discussion in 'Non-Husqvarna Motorcycles' started by JPinNC, Jan 4, 2015.
  1. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
    So hopefully some collective wisdom on this sight can help me figure this out ...
    My son and I picked up a 2003 Suzuki RM125 several weeks ago, in very good shape, but we are going through it as a project together. Anyway, the trans oil capacity is 750 ml, clearly marked. It takes about 950 ml to fill the trans using the oil level check hole. The bike was warmed up after filling and then allowed to sit, bike is being checked level. I looked over the clutch cover, etc. and everything appears to be appropriate stock RM125, so I just don't see how the extra 200 cc can be accounted for. Any ideas ?
  2. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
    Well I have thought about this and the only conclusion I can come to is the extra oil is entering another compartment. Most likely the crankcase. The bike is running rich and now I wonder if it is burning trans oil? He is going to ride it and see if the trans oil drops. I suspect a bad seal = time to split cases to inspect everything?
  3. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    Has the oil disappeared after sitting, or is it still 200cc over?
  4. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
    I plan to check tomorrow. I'll post the findings. It turns out that the right side crank seal can be changed without splitting the cases.
  5. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    Probably the right crank seal bad and your fillinf the lower end also....
  6. JimBob Husqvarna
    Iowa
    2013 TE310R
    There really isn't anywhere else for it to go. I wouldn't expect it to run very well with 200cc of gear oil in the bottom end. How long does it take when you are filling it with oil the get the full 950cc into it? Does it go pretty fast or more like a slow trickle?
  7. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
    The bike was run for about 2 hours and the trans oil has not dropped a bit. I think to confirm, will just run it one more time, drain the oil, refill it with the specified amount and recheck.
  8. Pepper Husqvarna
    Komoka Ontario
    2006 te 510
    2003 660 grizzly
    I have a 2006 TE 510 with the oil level bolt in the wrong place. also have two 125 Yamaha Grizzlys that say 1250ml on the crankcase beside dipstick but take 1450 to fill to top of dipstick
