Pw50 issue
Discussion in 'Non-Husqvarna Motorcycles' started by shawbagga, Feb 26, 2017.
  1. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Do these bikes have a clutch/driveshaft adjustment? Bike seems to run ok maybe lacking a bit of pickup from standstill but the rear wheel locks when pushing it with engine off. Can turn the wheel by hand but it turns engine over(can hear & feel compression). Never used to do it so thought clutch or driveshaft may need attention?
  2. oldbikedude Husqvarna
    Honey Brook Pa.
    sounds like clutch area....never had a problem with ours
  3. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    YEA IT SHOULD FREE WHEEL
  4. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Yes it should just not sure where to look first? I took the cover off rear hub(3x8mm bolts) but nothing in there to look at.
  5. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    its gotta be the clutch.. don't it? it dosen't try to take off at idle dose it ?
  6. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Yeh it surges a little bit. Guess that means clutch not disengaging properly?
    Hasn't had an oil change for a while but don't think it'd be that would it?
    Can't be that hard I guess I'll wash the bike then take a good look at it. Thought there just might have been an easy adjustment somewhere.
  7. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    i don't think so Hondas yes its that little screw with jam nut you see you might flush the hell out of it first see if that helps
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Are the clutches not like a mini moto and spring loaded?
    You may find a bust spring.
    Open her up man.
    PaulC likes this.
  9. oldbikedude Husqvarna
    Honey Brook Pa.
    I agree, broken spring or something with the weights in the clutch
    Bigbill likes this.
  10. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Roger I'll see what I can see today if I get the chance otherwise gotta wait a week until home from work.
    juicypips likes this.
  11. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Let the missus do it.
  12. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    I want it fixed not just yelled at.
    PaulC and oldbikedude like this.
  13. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Gave it a good wash(looks like new again funny that) & had a look. There's a plastic outer cover over clutch cover that must just be for protection. Held on by 2 bolts but can't remove it past the frame! Surely you don't have to remove engine to get the outer clutch cover off?!!
  14. oldbikedude Husqvarna
    Honey Brook Pa.
    Yeah ya do, it's just a couple bolts
  15. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Ahh shit really? Guess it's gonna be a day in the shed with a carton of beers job then!
  16. oldbikedude Husqvarna
    Honey Brook Pa.
    I don't remember exactly but I had the same response as you when I discovered the engine needs to be pulled just to get the side cover off the engine. I do remember it wasn't that bad though. good luck with it. We don't have that bike anymore.
    juicypips and shawbagga like this.
  17. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Did you sell it to Shwry?!?
    shawbagga and oldbikedude like this.
  18. oldbikedude Husqvarna
    Honey Brook Pa.
    You're on to me
  19. Bigbill Husqvarna
    '83 250wr
    0 right now
    Sounds like a rainy day with a 30 pack? Broken spring for sure. The clutch isn't fully releasing too.
    Ever notice the value on these little bikes. The little suzuki 50's are priced high. Through the years there all the same bike.
    shawbagga likes this.
  20. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Dunno why but there's 2 threads about this?! Bigbill on the money-broken spring=ruined clutch. Posted photos in the other same titled thread.
