TE/TC PWK Carb on te300 float bowl drain mod?
Discussion in '2st' started by HS507, Feb 6, 2016.
  1. HS507 Husqvarna
    NE Ohio
    Te 300
    Yz450,crf150r,crf100f,crf50f
    Is there a mod to install a screw with hose to drain float bowl instead of unscrewing cap and gas all over
  2. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    why?
    or you can turn off gas and run bike, yes there will be a little fuel down in the cap.
    I always run down bowl fuel before loading so it doesn't splash out of the vent tubes.
    my 1980 XR80 has that setup on it........
  3. HS507 Husqvarna
    NE Ohio
    Te 300
    Yes i could do this but when i want to rejet and things of this sort its easy to drain with hose screw set up. Spoiled with my yz450 i guess
  4. KddF1 Husqvarna
    Arlinghton Heights, IL
    2015 TE 300
    I'm with you HS507! I hate letting my bike idle, so i just shut off the gas an tip her over.
