Quick 81 stock exhaust question
Discussion in 'Vintage/Left Kickers' started by dumbdotdog, Jan 14, 2011.
  1. dumbdotdog Husqvarna
    Reno, NV
    70 360 74 125SC 74 250MAG 81 250CR
    I finally got my original silencer for my 81 250 cr project, It also has the stock original pipe, after looking at the parts diagram I see there is a connecting hose with two clamps. My question is both the stinger outlet and silencer inlet diameters are the same, do they just butt together or is my silencer wrong and one is supposed to slide into the other?
  2. adam6402 Husqvarna
    Tulsa, OK
    None
  3. dumbdotdog Husqvarna
    Reno, NV
    Thanks, I have seen that thread, Im just use to japanese bikes where the silencer fits into the stinger and a rubber coupler slides over the joint. Not shure how the Husky goes together.:confused:
  4. dumbdotdog Husqvarna
    Reno, NV
    Bump, somebody has to know
  5. Husq.fleet Husqvarna
    Pendleton Oregon
    My 82 CR 250 only uses the hose to couple the two together. Alot of the aftermarket silencers had a slip fit with a o-ring seal. The WR and XC silencers were slip fit also. The CR silencer also bolts direct to the frame and doesn't use the semi triangular alum. bracket. Hope this helps!
  6. dumbdotdog Husqvarna
    Reno, NV
    thank you sir, I was pretty shure, just not 100%
  7. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    I've got an 81 430CR that's like that... only the hose connects them together. I thought a previous owner had cut the pipe too short. Maybe not? Both my CR's (430, 500) bolt right to the frame with an 8mm bolt, no triangular plate like the XC/WR.
  8. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    I will be getting the stock any day now to couple the pipe and silencer together.
    The high temp.European made hose is 1 3/8" inside diameter and rated at 391 degrees F. and 200 C. color is black.
    I will sell them for $6 each or 2 for $10 plus shipping.
    PM me with your orders and let me know if you want 2 or 3 inch lenght.
  9. oldhuskychuck Husqvarna
    Denver Co
    the green {hose} was only to keep oil from spewing all over the rider, plastic ect. should have a rubber O ring inside that sort of seals with the pipe.
    a bracket hold it to the frame at the point at the seat attachement.
    you can get green high temp hose at any auto parts store for AC hoses,..pricey, but works well.
    originals had just one clamp, and other would have been added by a rider.
