Quick way to disconnect lights on SMR 510 for trackday?
Discussion in '4 Stroke' started by Luigic81, Sep 9, 2009.
  1. Luigic81 Husqvarna
    Hillsboro, OR
    Just wondering if there is an easy quick way, like pulling out a few fuses etc? I would perfer to disable the lights instead of just taping over them. Thanks in advance!! bike is '06 SMR 510
  2. priapism Husqvarna
    sherman oaks CA
    Yeah, you just yank the connector out of the back. Mine's an 05 so I don't have blinkers and whatnot, but I can do the swap in about a minute tops.
  3. Luigic81 Husqvarna
    Hillsboro, OR
    Sounds easy enough for the headlight, but the tail light and blinkers would be another story. I have a little LED tailight.....
    Is there not just a few fuses I can pull?
  4. priapism Husqvarna
    sherman oaks CA
    Honestly for the big bike I just tape over them with painters tape. Disabling them isn't a big deal, you just don't want them shattering if they hit the pavement.
  5. Luigic81 Husqvarna
    Hillsboro, OR
    ok gotcha, thanks
  6. So Cal SM450R rider Husqvarna
    So Cal
    I put a plug under the seat for the tail light and blinkers so I can just unplug it and take out 4 bolts that hold the aluminum bracket, which the tail light and blinkers are mounted to. Its quick and easy to remove/put back on. On the front, I take the glass bulb out of the headlight and run it like that. The front blinkers are leds mounted in my handguards, (Zeta XC's) so I leave those in. :thumbsup:
