250-500cc racing cilinderhead wr250 wr300
Discussion in '2 Stroke' started by QUATTRO, Oct 19, 2015.
  1. QUATTRO Husqvarna
    Hallo,
    Does anyone use a racing head on the wr250?
    What will be the difference to te Stock head?
    I looked by HTM racing Italy.
    Thee Sell heads
    Greets marco
  2. lankydoug Husqvarna
    MO
    WR
    TM 300en
    I'm not sure what year wr 250 you are asking about but I know on my 09 a racing head won't get you much since the factory stock head gets you about 205 psi cranking compression. The WR300 is another story and there is a gain to be had from the race head.
  3. QUATTRO Husqvarna
    Hallo ich have also the 2009 wr250. I have the fmf gnarly on it.
    The carb is the stock mikuni.
    I would do some mods to get it run smoother of idle
    I changed all ready the needle and main jet.
    Also a little more power would be nice
    Is it better to run with stock ignition timing with the gnarly or can I go a little earlier or later.
    The racing head will not help to increase the power?
    The form off the head looks also better with the nice squesch erea.
  4. lankydoug Husqvarna
    MO
    WR
    TM 300en
    My perfect settings for my Mikuni on my 09 wr250 with Gnarly pipe.
    32.5 pilot jet
    GAY needle in middle clip
    420 main
    air screw 1 turn out
    If you can afford it then get a 38mm Lectron carb. It will run better everywhere and use a lot less fuel. I wish I had bought a Lectron before I spent money on jets and needles to tune my Mikuni which has been sitting on the shelf for the last 3 years.
    juicypips and NCSteve like this.
  5. QUATTRO Husqvarna
    Oke thanks for the answer.
    I run 430 main with 40 pilot and needle from the power kit husqvarna. Needle clip on third.
    I think main would be a little less 410 or 420 and pilot 35 37.5
    But at the moment it is almost ok for me wenn it will get a little better of idle is ok for me
  6. QUATTRO Husqvarna
    I'm from Holland the adjustment would be here a litte different to us i think.
  7. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Your bike will probably idle better with a smaller pilot. My settings are for 1,500 ft above seal level (about 500 meters), usually around 2,000 ft (about 700 meters) air density altitude. I think the Husqvarna power kit comes with the GAY needle, it will be stamped on the needle near the clip grooves. Your 230 main should be good assuming your air density altitude is less than at my location.
  8. QUATTRO Husqvarna
    I will try it ordered the jd needle kit as well to try.
    I heard the mikuni carb from 2009-2013 wich I have would be better than the older tmx.
    The jd comes with two needles wich one do you think will be the best for Holland.
  9. lankydoug Husqvarna
    MO
    WR
    TM 300en
    I don't have any experience running a JD needle. The GAY needle should work fine, it worked for me in the middle groove from 1,500 ft in Missouri to 9,000 ft in Colorado with only a tweak on the air screw. If your bike is running fine except for the idle you should not change anything but the pilot and maybe try playing with the air screw and idle screw, then once you have the idle sorted then decide if the needle or the main need adjusting.
  10. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    I think with the JD Kit the important part is the nozzle (or needle jet). The JD Kit will come with recommendations on which needle to use for based on your riding altitude and temperature.
  11. QUATTRO Husqvarna
    Oke I didn't now that also the needle jet was included. Are normally also pilot jets included?
    I ordered the kit in Germany and it comes with three days to holland :-)
    Also now I will have more variations to test.
    Off throttle it's blubbering but at half throttle it's to lean I can't wait to test.
    The htm racing company also sell spacers for between inlet and cilinder, does anyone has a Idee what will be the difference with those spacers.
  12. gwynfryn Husqvarna
    2009 wr250
    I have the jd kit on my 09 wr250.
    It comes with 4 main jets 380,400,410,420
    32.5 pilot
    s-9 nozzle
    and two needles, red and white.
    There are comprehensive instructions included but I have ended up quite a bit leaner (except main) than where I started.
    After two years riding and several different combinations I have found the best setting for my bike and conditions is:
    s9 nozzle
    white #4
    30.0 pj
    420 mj
    Standard pipe
    40:1
    sea level to 100m
    20 dg celsius
    It absolutely rips from idle to max rpm, starts easy, will idle all day, plug light tan. I put a new piston in at 90 hrs but could have easily done rings only. Over half the bikes total hours(about 130 now) have been racing and a lot of that in sand.
  13. QUATTRO Husqvarna
    Oke nice to hear thanks a lot.
    I have now pilot 40 32.5 looks very little but we will see.
    What do you change in summer to winter only the main 10 bigger or even more?
  14. QUATTRO Husqvarna
    Installed today the jd kit and it works just fine.
    I used the red needle third spot
    Pilot jet 35
    Main jet 430 (winter and below sealevel)
    Runs great what an improvement
    I had the J8-6DEY15-74 needle in it whit 440 main and R-8 needle pipe.
  15. dan hiltunen Husqvarna
    canberra australia
    wr300
    te511 Xr600
    I bought the kit from htm. Cylinder, graphite piston, black race head and the spacers. My wr has now become a 450 destroyer. What a weapon. I also run the kiehin pwk and red jd jetting needle. Jetting can be fun. I now run 35 pilot and 162 main. If you are looking to jet your bike it will usually be different from one bike to the next so just trial and error. Pipe seems to affect jetting also. Love this thing. What a ball tearer!!!
  16. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Never hear if htm racing before. Got heaps of gear!!! Can't get prices tho on website n in Italian?
  17. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    I read the translated version and sounds interesting. Guess you gotta call and hope for an English speaking tech.
  18. QUATTRO Husqvarna
    Hello,
    They speak english no problem at all.
    The racinghead and spacers are a real improfement.
    I use the FMF exhaust and one inlet spacers
    I just had my engine rebuild and have now the 6 gearbox from the WR360
    front 15teeth and 47 rear
    new piston and rod etc.
    Now had to make a little changes to the jetting
    JD JETTING WITH MIKUNI TMXX
    iddle 27.5
    Main 440 (spark plug nice brown :-) )
    needle clip second position
    jetting is perfect everywere
    the bike is realy strong and the 6 gear is ment to be a overdrive but i can ride in de sand standing on de bike easely about 130km/h
  19. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    remember to jet for temperature and altitude
