Racing the 430 Auto at Stone Hollow
Discussion in 'Vintage/Left Kickers' started by cruisetopdown, Sep 29, 2015.
  1. cruisetopdown Husqvarna
    VA
    1982 and 1983 Husqvarna 250 XC's
    Had another fun ride at the North Atlantic XC series, this time at Stone Hollow just east of Pittsburgh PA. Once again Dave and his crew did a great job laying out the trail and making sure the guys all had a great time. The Final event for the series is Oct. 17th, the Johhny B Classic.....last chance to drag that old vintage bike out of the shed and dredge up some old memories!
    Hope to see you there.
    w
    View: https://youtu.be/dWfkvthRE50
    oldbikedude, Krudd and everfree like this.
  2. Michel Dufayard Husqvarna
    France
    The idle seems low and better. Nice view from Virginia !
  3. cruisetopdown Husqvarna
    VA
    Yes, I went to a 35 pilot (from a 40) and reset the idle and she seemed to respond well. It sure seems to take forever to get the idle to settle down so I can get it in gear! it's really in my head as the competition is speeding away....I continued to have a water pump leak though, and will have to take a closer look at the housing.... maybe it's warped? the new gasket pushed out closest to the boot side of the pump housing. I inspected it very closely and didn't see any nicks or damage area, i'm somewhat puzzled.
    w
  4. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    its not coming out the weep hole is it? mine always dribbles a bit out thru there
  5. cruisetopdown Husqvarna
    VA
    Turns out that the housing was warped and allowing the new gasket to push out slightly when it tightened down, then would hiss coolant under pressure. The housing was decked on flat surface with sandpaper and seems to hold the gasket now when tightened. I'll try to get it out and test ride it to be sure it's fixed.
    w
  6. Palito Husqvarna
    Ontario, Canada
    2009 WR300, 1986 430AE Auto
    1989 DR600
    I use 3M weatherstrip adhesive to glue the flat rubber gasket to the aluminum engine cover, keeps it from slipping out. Try not to tighten too much that's how they get warped.
    Good luck.
  7. oldbikedude Husqvarna
    Honey Brook Pa.
    Nice video. That bike sounds tight. Sounds great.
