1. chamber66 Guest
    I love the look of the rad shrouds on my Husky. But why do they have to be two piece?
    I am constantly getting bits of branch and bush jammede in there, and one side has now torn free. Is there a solution to this problem as it is starting to get expensive?
  2. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    the design is for quick maintenance, one screw removes the tank along with separating the shrouds. There are always plusses and negatives to all engineering logics.
    You are correct about the branches and sticks issue. Its something we all just live with when bush wacking our Huskys.
  3. chamber66 Guest
    Shame no one makes a one piece panel really. I have now resorted to riveting this set together, which i have to say doesn't look that good unless you really like the Mad Max look :confused:
  4. raisrx251 Husqvarna
    Virginia
    Next time try running Black Duct tape on the inside and bring it over the joint to the outside slightly. I have not had that problem with brush anymore plus I have not broken any of the tabs knock on wood.
  5. Brad_O Husqvarna
    On my TE250, have drilled two very small holes between tank shroud and rad conveyor, small piece of safety wire through keeps sticks and branches out, but can be removed trailside if you need to remove tank, and easy to replace
  6. dfeckel Husqvarna
    Medford, NJ
    I did the same thing with cable ties--definitely keeps the foliage out.
  7. 420skirider Husqvarna
    Phila, Pa
    Where I ride it's so tight I'm always tearing off the shrouds if I leave them stock. After going through at least 3 sets of shrouds, I purchased a set of UFO tank shrouds ( $25/ea. w/out sticker) and a spare set of rad shrouds($10 ea.) and cut them back to almost the front off the tank. It really doesn't look bad if you take the time to line up the cut lines for the shrouds( I mount them first then use a grinder with a cut-off wheel). No more torn or broken shrouds and it only takes 10 min. to switch them out if I want to dress up the bike for an "open trail" run.
  8. brock Husqvarna
    UK
    Instead of using zip ties and lock wire, use a DZus fastner so you can undo it quickly and it looks great too!
    Where the tab is on the rad panel drill both the rad panel and the tank panel so you can hold the pair together with your little anodized dzus :thumbsup:
    Alec
