Radiator Caps
Discussion in '4 Stroke' started by DirtyOldMan, Dec 13, 2009.
  1. DirtyOldMan Husqvarna
    Pleasant Hill MO
    13 Terra
    15 Beta XTrainer 04 250 RFS
    I have searched but my search skills are poor.
    I want to put a stouter rad cap on my 06 510.
    Currently has a 1.1 . Folks here seem to like a 1.4 or a 1.8.
    The ones I'm finding are 20lb and 30lb. I'm not sure how they correlate to one another.
    Also, rad caps do not appear to be brand specific. Is a rad cap just a rad cap? Interchangeable? Never bought one before.
    What do I need and where can I get it?
    Thanks
  2. demi Husqvarna
    Cheyenne, WYO
    12 WR 300
    '14 SH 500, 81 Gilera 125 C1, 17 KTM
    I have a Kawasaki 1.8 on my 08 TC 510. fits nice.
  3. fitness2go Husqvarna
    Seattle WA
    Is that a standard cap that Kawasaki uses? So if I go to a Kawi dealer and ask for a radiator cap, they should give me a 1.8 that works?
  4. demi Husqvarna
    Cheyenne, WYO
    12 WR 300
    I am pretty sure it is standard, the part number is 49085-1077
  5. fitness2go Husqvarna
    Seattle WA
    Thanks for the part number!
  6. socaltrailrider Husqvarna
    Tustin, CA
  7. RLW Husqvarna
    Boise, Idaho
    Maybe this will help?
    http://www.cafehusky.com/forums/showthread.php?t=4997&highlight=radiator cap
    As mentioned in link, I bought a CV4 20psi cap (1.4bar). I had heard good things about, and it appears to be a nice cap, but due to work/weather I haven't been able to ride since I bought it at the end of Aug (& now have blown truck engine) ......so not looking like I'll get a chance ride and try that new cap until next spring now.
  8. ghte Husqvarna
    Bright, Victoria Australia
    I know that the KTMs went from 1.4 to 1.8 a year or so ago, however they do not have an overflow tank. The 1.1 seem to be ok assuming you are using a top notch coolant imho.
  9. bower100 Husqvarna
    Wilmington, DE
    '83 250CR - '07 TE450
    TY350Trials-BetaRev3-'77RM250-'80YZ
    I did a little research on the Kawasaki radiator caps.
    All from a KX500 parts list:
    # 49085-1070 ----- 1.1 bar
    #49085-1073 ------ 1.6 bar
    # 49085-1077 ----- 1.8 bar
    The 2005 KX450 takes a 49085-1078 but it doesn't say what pressure rating it has. Whether it fits the husky radiator ... I don't know.
    Dave
  10. Husky ran stout Toyo rads through 05, switched to flimsy Alexons in 06-07 and back to Toyos in 08. My 07 TE510 came with a 1.4 bar cap.
  11. KDXfile Husqvarna
    Alabama
    I run the CV4 20psi cap and removed the overflow tank and hoses. Working good so far.
    They pretty much fit universal. It fit my old Honda, KTM, and the new Husky.
  12. ajaxauto Husqvarna
    I have a 2006 TE 510 and yes a Kaw cap will fit BUT WHY if you run the Zip TY waterless coolant the only reason you need a cap is so the coolant will not spash out as it will not boil .Going on 4 years many expert races and rides and never lost a drop
    Stock works for me The stuf is waterless so it will not boil
  13. Jrmobb Husqvarna
    Simi Valley,ca
    Almost all liquid boils, just at a higher temp. Ive had my engine ice boiling more than once. Most waterless coolents ive seen boil at around 370f, I think engine ice boils around 250f. By getting a high temp radiator cap its doing the same thing. keeps the system pressurized and prevents water from boiling.
  14. ajaxauto Husqvarna
    At 370 i would think something else will blow before the coolant does
    With a higher cap you put the coolant system under more pressure
    Why do that if you do not have to .Plus if there is no water it will not rust and wear out the parts.
    But everone is different so do what works for you
  15. fitness2go Husqvarna
    Seattle WA
    For peace of mind, a higher pressure cap and waterless coolant is for the rare time that my engine temp spikes and wants to boil out coolant...now it won't do it. In the past, I have puked out some and at times, all of my radiator fluid (Engine Ice). I don't want it to happen again because when I lost some of my fluid it compounded the issue driving the temps up and up, puking more and more coolant. I also have the Trail Tech Vector with a temperature gauge to monitor things.
