Radiator Guard - Polycarbonate - Easy clip on/off
Discussion in 'TR650' started by kiwiape, Nov 21, 2015.
  1. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    Decided to make my own after looking around, video says it all. Time will tell if the Polycarb will last....I am using rubber feet to stand it off the radiator core, give air gap, stop chaffing and reduce heat. Considering you need about 160 Celcius to bend it I think it should live ok here.....:).
    View: https://www.youtube.com/watch?v=OlDFllBFNwA&feature=youtu.be
  2. glitch_oz Husqvarna
    AUS
    Strada
    I'm sure the Polycarb will last just fine.
    Nice piece of work, too!!
    Love the easy clip-on and rubber stand offs.
    Taking orders?
    nev.. likes this.
  3. duibhceK Husqvarna
    Chapel of the Well, Belgium
    TRX850; WR450F; XT660Z Tenere
    Looks really nice. What is the clearance with the mud guard installed?
    Pepper likes this.
  4. LED Husqvarna
    Perth, WA
    TR 650 Terra
    Good job kiwiape.
  5. Rulyx Crossman Husqvarna
    Canary Islands - Spain
    HUSKY TERRA 650
    Kawasaki KLX 250
    My question is: This piece will not make up more temperaratura engine to cover the surface of the radiator? The terra Husqvarna is a motorcycle that was originally very hot with the original radiator without any parts that cover it. The radiator cooling fan on my bike is operated frequently. More than it should be correct.
    I love design and is pretty to look at.
  6. Baddrapp Husqvarna
    Yucca Valley
    TR650
    I would suggest the thermostat delete and switch out the coolant. It really does make a difference.
  7. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    I like it. How well does the poly stand up to rocks compared to a wire mesh? Cleaning mud out is probably a breeze.
    And the most important question, Does it come in candy cane red and white stripes? :cool:
    Big Timmy likes this.
  8. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    Thanks for the kind words fellas.
    Orders...maybe...?? now that I have a pattern, which one took me about 8-9 hours to make excluding the CNC part.
    Clearance to guard is about 6mm, we can adjust this by adding more washers to the rear mount as Mr Husky did at the factory.
    Cooling - don't know yet haven't ridden it.....I don't think it will make any difference to the riding I do, even on slow stuff when the fan comes on I doubt the fans effectiveness will be changed....theres plenty of gaps. My bike (touch wood) has not had any issues at all in this department to date.
    Polycarb toughness. The odd stone and stick should not be a problem..... try hitting polycarb with a hammer and you will struggle to break it!.
    Colour red & white stripped, yes of course, but there is premuim:)
    Worse aspect - cleaning it requires front guard removal.....I could change this, but I like the way it hangs from the top, should it ever come lose it cannot fall off.
  9. Cyntax Husqvarna
    The Netherlands
    TR650 Terra, 900R Nuda
    MG V50 NATO III
    It is definitely lighter and prettier than its aluminium counterparts. Fantastic work Kiwiape!
    If you're going to produce more of those I might be interested too.
  10. sussurf Husqvarna
    Port Macquarie area, NSW
    Triumph Sprint 1050, Daytona 955i
    Look forward to pricing Kiwiape
  11. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Thats proper neat!
    You should copy right it an produce for other brands thats a winner right there.
  12. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    Thanks guys. Can I have a hands up on how many might be interested??. and I'll have a look at costings etc.
  13. sussurf Husqvarna
  14. Cyntax Husqvarna
    The Netherlands
    MG V50 NATO III
    I am interested for sure!
  15. sussurf Husqvarna
    I'd be in for 3 or 4 units Ape
  16. Scott Johnson Husqvarna
    Minnesota
    Count me in on one of those guards!
  17. rww Husqvarna
    Kennewick Washington
    tr650
    Ducati, Cagiva Kaw Zuki Honda
    +1....... looks good
  18. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
    I like the moulded cutouts for the radiator fan mounts, but are the radiator fans identically mounted on all TR650s or done individually by hand in the factory (and therefore with some variation thrown in).
  19. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    Good point, I have a 1:1 drawing I would send out for everyone to check, failing that you can drill your own holes.
  20. Ignaciob Husqvarna
    Tri-Cities, WA
    TR650 Strada --> Terra (aka Noxeema)
    05 Yamaha FJR (x2), 75 Honda CB400F
    Interested.
