Radiator replacement
Discussion in 'TR650' started by Glengemen, Dec 30, 2013.
  1. Glengemen Husqvarna
    Las Vegas NV
    Yamaha Raider 1900
    Took the radiator out today. Not the unbolting type method ether.
    Does this share a radiator with the G650GS? Googled, but nothing concrete.
    The part number is 8000H5220 and the cost is 358.75 from KTM-parts.
    Maybe someone has one? I'm in the market. I'll take it by a radiator shop tomorrow and see what they can do about it. image.jpg image.jpg
  2. oneal Husqvarna
    uk
    1999 wr 250 returned home.
    07 TE 450 2005 TE 450 1999 CR 125
    Could it not be repaired by some one like Mylers or GMX It may save you some $.
  3. Glengemen Husqvarna
    Las Vegas NV
    Yamaha Raider 1900
    It is leaking on the tank seam. If it can't be fixed for that money I'll see about having one made!
  4. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    Just out of curiosity, does it have a thermostat inside? We were discussing its whereabouts in another thread awhile back.
  5. Glengemen Husqvarna
    Las Vegas NV
    Yamaha Raider 1900
    Yes, the thermostat is inside the radiator.
  6. vodka Husqvarna
    South Australia
    TR650 Terra ABS
    R1200R , Yamy WR250R
    The way things are for spares,its soon that someone will cannibalize a perfectly good tr650 and make a profit whilst undercutting the OEM suppliers by magnitudes. Indeed there would surely be some who would stock up on vulnerable parts.
  7. Motosportz CH Sponsor
    A good rad shop that does custom work for vintage cars can build almost anything.
  8. Glengemen Husqvarna
    Las Vegas NV
    Yamaha Raider 1900
    I brought it in to see if it can be fixed, if not I'm more than likely going to have an aluminum one made. I'll find out next week.
    On a side note my Christmas present that was back ordered shipped today. CRASH BARS! oh the irony!
  9. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    Just wondering if it's positioned in the tank between the inlet & outlet pipes? Is it open when cold & closes when the coolant heats up allowing circulation across the core (twin pass design)?
    If so, take this into account when designing your aluminium unit.
  10. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Looks identical to the F650GS except for fan position.
  11. Glengemen Husqvarna
    Las Vegas NV
    Yamaha Raider 1900
    Looks close, but the mounting is very different though.
  12. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    I'd have yours repaired if possible. You can run my coolant which is waterless, it won't corrode like normal coolant and only operates at 1-2psi. Should get longer life out of your cooling system. :excuseme:
  13. Glengemen Husqvarna
    Las Vegas NV
    Yamaha Raider 1900
    Sounds like how my cooling system was after I broke my radiator! Waterless and 1-2 psi!
    Centerline, vodka, Motosportz and 2 others like this.
  14. Gibster Husqvarna
    Reno, Nevada
    '84 XR350R
  15. Kenneth Webb Livin' It Up!
    Tucson AZ
    TE630 TR650 Terra TE310R
    Tinken, I couldn't read the fine print on the XF+ coolant but I assume that it is also an anti-freeze. Yes? Suitable for serious long term dual sport use, not just racing?
  16. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
  17. Kenneth Webb Livin' It Up!
    Tucson AZ
    :thumbsup: Thanks Tinken. Think I will try that in my TR650 as well as my other dual sports.
    Tinken likes this.
  18. Kenneth Webb Livin' It Up!
    Tucson AZ
    'Just purchased two gallons of XF+ and it will be going in in short order.
  19. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    The bottles are half gallon. Did you need that much? Most bikes like the 449/630s only take a quart, so a half gallon is plenty. Course if you have multiple bikes, that may work out for you?
  20. Kenneth Webb Livin' It Up!
    Tucson AZ
    Yes, for two or three bikes if it goes around. If not, I'll order more. The TR650 is the one that seems to run hotter; the fan comes on when climbing or doing tight trails. The WRR and TE630 less so but on occasion..... I will be doing a 5000 mile plus trip this summer on the WRR and that will be a good test for me.
