I just wrote a long dissertation on this with my story from this week and my computer dumped,,,so this is the short version after riding and doing heat cycles re-torque all your engine case and cover screws and your motor mount bolts. mine were all loose some were very loose. R
Thanks for the reminder Robert. Not long after break in my 510 started leaking oil from the engine case. It looked like it was coming from under the starter. I was going to take it down to the dealer for a warranty issue. I started poking around and found that most of the bolts holding the case together were loose. Tightened them all up, and it hasn't leaked a drop since. Ken
As much as i love the 08 they sure have a lot of loose bolts the 04-07 models never seemed to have. Subframe and rear sprocket bolts should be checked regularly.
Might want to check the header bolts as well. I lost 3 out of 4 somewhere in remote Kingston Canyon in Nevada last Thankgsgiving. At first I just thought it was getting louder due to the sound bouncing off the canyon walls, but no. I used a few spare bolts and a bolt from my airbox cover for the rest of the trip. WoodsChick
I just recently purchased a 2008 510te, what is the right lbs of torque to tighten the engine bolts, header bolts and sprocket bolts?
It seems pretty much necessary to give the bike a good once over every few rides. I find keeping the bike clean and re-greasing regularly enforces this as you're visually inspecting almost everything. I tore down the swingarm/linkage a while back for maintenance and found a bolt had come loose and was cutting a groove into the wishbone on the linkage.
Something else that is often overlooked (well, I did anyway!) is the chain rollers. Mine looked fine, with no grooves etc, but when I took the chain off for cleaning, I happened to spin one of them, or at least tried to. They were both seized - not solid, but enough to stop them spinning properly. Half an hour with penetrating fluid had them spinning freely again - obviously the seals aren't too good. I do spend a fair amount of time in mud and water (not always upright either!), and the pressure washer can't be good for them, but it has made a big difference to my bike - I had an annoying rattle on it that I just couldn't pin down. After freeing the rollers, it was nice and quiet again Mike
