I read the instruction supplied with the X2 headlight and the instructions supplied with the trailtech reg/rec. Everything hooked up, everything works...........Not sure I did it right. I can't be too far off cause I haven't fried my electrical system yet but can some one break down to me how you are running your headlight? Also how do you have your stator, reg/rec wired? Is there a better way than others to wire it up? The light still dims when I let off the gas. Is that still normal or is the light supposed to be full power under all RPMs? Granted I have not ran the bike at night yet so can't judge just how bright it is. I have the 2" wired to the little park light that was always on and the 4" wired into the high so both are on on high. is that a common way or just a flat out wrong way? I'm no electrical guru any help would be appreciated.
