Help! I broke a 2008 TE610 clutch lever at the hinge pin. Unfortunately, I can't get a replacement delivered until next week and I was hoping to ride this weekend. Does anyone one know of an alternative lever from a common bike that might be available at the Albuquerque Cyclegear or a non-husky dealer that would work? Nearest Husky dealer is 500 miles away! By the way - after riding 50 miles home without a clutch I realize these bikes only need one for starting out! Thanks in advance, Howard
Howard, I Replaced mine with and ASV lever and perch with the hot start that is controlled with your thumb. I use the hot start for the choke, I added a wave washer between the hot start lever and the perch to give it some friction so the choke will not return on its own. Note: You can have my old lever and stock perch if you want? Good Luck Dan L
The KTM's, ATK's and Aprillia that us the cable clutch will work. But it may not make the clutch safety switch work right. From what I understand you just connect the wires to over ride it. Edit: went and found the info I posted some were else. ATK and acouple others have also used this same clutch lever. KTM Years 90-96 Husky Husaburg
Thanks! Dan L & Red Dog: Thanks for the quick replies. I apologize for overlooking the thread about the ASV levers! Howard
Howard PM me if you still want the lever and perch I may have a pic of the way I did the choke, let me know if you need Dan L
Okay I had the same problem with the clutch lever. I found out from the Domino's web site that, lever for KTM LC4 620SX should fit. And the local KTM guy did have that. The only difference was that the plastic part at the end of clutch cable wouldn't fit. So I have got rid of that and put the lever. It works OK. Now there are several options which are foldable and should be more crash resistant like http://www.motocrossgiant.com/Sunline_V1_Flex_Clutch_p/56-21051wps.htm WOuld this fit straight forward to the Husky original handle bar? Did anybody try those? Regards
