250-500cc Rear brake locked up andcocked the braided line today
Discussion in '2 Stroke' started by firecrotch, Jun 1, 2014.
  1. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    Last mile of riding my 300 seemed down on power. Ride up trailer ramp at end of ride and notice rear line is smoking. So start to lean in and the thing burst broiling brake fluid everywhere. missed my face my an inch. Sheesh. All my years of riding this has never happened. Any suggestions what happened? I will buy new braided line, new brake pads but am wondering if needing a caliper rebuild kit. Do they make them? If so will do it for front too.
    Only thing to know about my rear brakes is rear pads where almost border line metal on metal. I figured one more ride and that was it. Could that have done it(yes I know I know i didnt intend to let it go that far but....)?
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Use Motul brake fluid, and change the fluid whenever it gets dirty. Contaminated brake fluid has stuff in it that expands when it gets hot, then puts pressure on the pads and makes things even hotter, faster!
    Glenn haynes likes this.
  3. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    I forgot to mention I actually do use that motul stuff. Been about a year since last changing of fluids though. Hasn't mattered in the past?
  4. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    You almost ended up like the guy in your avatar
  5. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    wouldnt be first time-lol
  6. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    i reckon less pad equals more fluid being used to fill pot & actuate piston meaning gets hotter. pistons may have stuck from being too far out or possible dragging? did you adjust freeplay recently when brakes were cold? i had it happen on my front brake, was sweet in garage & around street but under heavy braking there wasnt enough freeplay & it locked on! haha my brother was riding it at the time & nearly went over the bars-lucky!:eek: disc was blue hot! had to crack banjo to release some pressure. come to think of it ive had it happen on rear too, i just like minimal freeplay & powerful brakes:thumbsup:. allow extra for expansion when hot is the moral of the story i guess. check ya disc thickness too as that wont help if theyre too thin, theyll get hotter quicker & tranfer heat to pads/fluid. ps nice work on blowing a ss braided line man-WOW
  7. Super5onic88 Husqvarna
    Perth, Australia
    SMR 449
    RGV 250
    I had the same on my SMR449 not enough free play on pedal locked up on me at 90km/hr. All I did was change pads and fluid. Rotor wasn't warped so all good.
  8. rancher1 Husqvarna
    WA
    Sounds like you had no room for expansion, or something was stuck.
