250-500cc Rear brake problems on 2000 wr250
Discussion in '2 Stroke' started by haulin husky7, Jun 7, 2010.
  1. haulin husky7 Husqvarna
    SWVA
    13 txc310, 2000 wr360
    2016 TM 300en, 93 KLX650R, 1975 XR75
    I got a 2000 wr250 that has rear brake troubles, no matter how much i bleed them they never seem to build any sort of stopping power back. when they do build pressure back you ride the bike a couple of yards and the rear brakes start to fading thus having no pressure.
  2. motosportz mike CH Sponsor
    Washington state
    bent rotor or a leak somewhere in the brake system.
  3. haulin husky7 Husqvarna
    SWVA
    I dont have a bent rotor or leak it holds fuild, when i bleed them the fluid comes out black.
  4. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    The system isn't clean enough inside. Contaminated fluid will cause problems including sometimes leaking fluid out or air in through the plunger or around the piston. If you have not completely disassembled the caliper with the piston out, and the master cylinder with the plunger out, you should try that. Make sure that everything is clean and dry before reassembling.
  5. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    What she ^^^ said, +
    Try removing the caliper and holding it straight up above the master and bleed them until they pump clean fluid.
    You'll have to put something between the pads to take up the space of the rotor, or it might push the piston out.
    If that doesn't work you may need to rebuild the master.
  6. Motosportz CH Sponsor
    Yep, sounds like you need to completely disassemble the master and slave and clean it all out and inspect. I bet the master needs rebuilt (simple). then once it is all clean and new o-rings etc refill and bleed. your brakes will be like new again.
    FYI - If you ride a lot I recommend purging and refreshing the brake fluid twice a year. Amazing how much better the brakes work when fresh.
  7. Motosportz CH Sponsor
    Man this a great forum. Look how fast the right solutions are presented here. Love it. :thumbsup:
  8. haulin husky7 Husqvarna
    SWVA
    thanks for the tips I will try some of it out.
  9. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Reverse bleed it. Get a nice turkey baster, safety wire a length of hose from the baster to the nipple and push the fluid from the bottom up using the T baster. It pushes the air up (where it wants to go anyway) and should push any contaminants through the system with it.
    It will make a huge mess!
    If that fails, it's time for a m/c rebuild kit.
  10. haulin husky7 Husqvarna
    SWVA
    where can I get a rebuild kit for the master cyclinder.
