125-200cc Rear disc model crossover
Discussion in '2 Stroke' started by shawbagga, Jul 31, 2017.
  1. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Had a quick search found nothing. The 09-13 wr/cr125 rear brake disc is the same as te/tc/txc250/310/450/510/449/511 correct? I'm fairly certain they're the same just different width hubs?
    Getting new discs all round on both bikes soon through an Aussy mob but they're not sure they're the same disc(different part numbers on their site). I'm 99.99% sure they are? 240mm 4 bolt(250/300 are 220mm 4 bolt). She asked me to take wheel off & measure to be sure but CBF TBH. Thanks y'all
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    having access to the Husky OEM parts list is fine and handy,,, but in the real world the guy that fixes them as in the dealer sees a VERY similar part with a different part number, yes you should ask but I agree with you, probably the same, maybe the grooves are different
    and on the hubs, why would they be different? maybe a lighter hub on a 125, that was me reaching so don't quote that
  3. Oldscool Husqvarna
    South Australia
    None
    RM125, SWM RS500R & Superdual
    Dont the 4t have floating discs??
    Bolt pattern is probably though.
    Glad I could help lol.
  4. SmokeyExpress Husqvarna
    Canberra Australia
    2014 WR300, 1996 WR360,2013 WR125
    I have access to the parts fiche. It is the same part. Part number is 8000 H4977
    They are a solid mount wave rotor, 240mm diameter made by Braking Italy.
    shawbagga likes this.
  5. SmokeyExpress Husqvarna
    Canberra Australia
    There is also a variation part number 8B00 H4977 used on some 4T models but they are still 240mm & given that the hub is the same as well as the caliper that part should interchange.
    Also note, that part number may denote a wave or drilling patten or thickness or even finish difference, maybe even region, but should still work.
