rear fender
Discussion in '4 Stroke' started by richard kersten, Sep 25, 2013.
  1. richard kersten Husqvarna
    Yucaipa Ca
    2012 te 310
    klx 250s vulcan 900 yamaha stryker
    I want to clean up the rear fender and remove that plate light and raise the plate up higher , what do you do with the wires just snip them ? thanks
  2. oregonsage 4st Clerk
    Dry Washington
    FX450
    Yamaha DT400 x 2, BMW G310R
    I believe you will find that all wires plug in someplace between the light and the battery....just unplug at the junction.
  3. richard kersten Husqvarna
    Yucaipa Ca
    2012 te 310
    Thanks
  4. eel125 Husqvarna
    NJ
    2013 TE 449
    How do you plan on cleaning it up ? Are you going to use flush mount rear blinkers ? I was thinking of just cutting off all that extra plastic where the plate is mounted now . Post pics of your finished product . I'm going to do mine over the winter so I'm looking for ideas
  5. TITO Husqvarna
    El Paso, TX
    2013 TE511
    KTM 450 XC-W, CRF450R
    I am also looking for this info as my new turn signals are on the way! Thanks
  6. richard kersten Husqvarna
    Yucaipa Ca
    2012 te 310
    Will do , lucky me no real winter in southern California
  7. TITO Husqvarna
    El Paso, TX
    2013 TE511
    do you have to cut the plastic? or does it actually come off?
  8. richard kersten Husqvarna
    Yucaipa Ca
    2012 te 310
    looks like I am gonna have to cut the plastic
  9. oregonsage 4st Clerk
    Dry Washington
    FX450
    Or buy a TXC rear fender and save the stock one.
    richard kersten likes this.
  10. eel125 Husqvarna
    NJ
    2013 TE 449
    Keep us posted. I'm sure someone on here has done it.
  11. my_urban_chaos Husqvarna
    Edwards AFB
    TE310
    Kwak Z1000
    I just took off the black plastic, to include the blinkers, and used the white plastic as the backing for the license plate. I then created small turn signals attached to the 8mm bolt heads that are in the wheel well area. There are some photos of this on the chat board somewhere. Racing and trail riding all told the blinkers still work and I've had no issue with the plate hitting anything.
  12. Super5onic88 Husqvarna
    Perth, Australia
    SMR 449
    RGV 250
    Here is what I did.
    Just fitted two little LED's under the taillight for numberplate illumination.
  13. richard kersten Husqvarna
    Yucaipa Ca
    2012 te 310
    Are you running street tires ?
  14. TITO Husqvarna
    El Paso, TX
    2013 TE511
    Did you have to cut black plastics or does it bolt off? I have some flush mount leds on the way...also how did you wire LEDs for illumination? Thanks!
  15. Super5onic88 Husqvarna
    Perth, Australia
    SMR 449
    RGV 250
    Yep it's a road trim SMR449.
    The LEDs were just double sided taped to the under side of the taillight.
    The standard plate light uses bullet terminals so I just crimped some new terminals on the LED wires and plugged them in.
    That photo is just a trial fit with zipties holding the plate on. But I was going to drill two holes and put rubber mounts under the plate.
  16. Super5onic88 Husqvarna
    Perth, Australia
    SMR 449
    RGV 250
    The stock SMR fender looks like this
    It has two bolts under the top fender and the three plugs to remove the whole thing.
  17. SDPUTTER Husqvarna
    San Diego
    2011 TE 511
    Crash tested some flush mount LED's....held up better than the bars and sub frame :D
  18. TITO Husqvarna
    El Paso, TX
    2013 TE511
    Finally got my LEDs from sicass, as well as my key switch...couple of hours later got everything going! Excuse the mess!
    [IMG][IMG]
    [IMG][IMG]
  19. TITO Husqvarna
    El Paso, TX
    2013 TE511
    Where did you get those LEDs?
  20. richard kersten Husqvarna
    Yucaipa Ca
    2012 te 310
