I have a spare rear wheel with a knobby, but not a spare rotor, so I have to swap rotor between wheels when needed. One of my Rotor bolts is buggered up a bit, I can still get it out, but Id like some new ones but not sure what size to get. Any help appreciated!
I put these on the TE 2008 rotor and they fit: Pro Taper Rear Sprocket Bolt Kit Item: P357217 SKU: 1176993
Is your rotor floating? does it have the bushes? the bolts for those were M6x14mm flange bolts there is a guy on Instagram stormworksgarage in the UK he can get OEM rotors for 2000s huskies if you wanted another rotor to go on the wheel message him
Thank you Sonnie and Jon!, Sorry I hadnt checked back in, I feel that was rude of me. I will send a Message to see about a second Rotor.. I'll look up that Pro taper sprocket bolt kit as well, Jon, much appreciated. It would certainly stream line the swapping, not that its overly time consuming! I went throug ha couple hardware stores and could find the 6x14MM but it wasnt a flange bolt. Much appreciated!
