rear rotor - floater - question
Discussion in '610/630' started by Bikyto, Dec 6, 2010.
  1. Bikyto Husqvarna
    Nor Cal
    hello everyone,
    New here even though i've been a lurker for a while.
    I had a quick question about a 2006 SM610 rear rotor. How much "slack" do you guys have in your rear floater rotor. Mine seems to move quite a bit (about 1mm side to side and front/back) but I don't see much sign of wear.
    Thank you in advance. New (to me) bike! Yahooo!
    That would be my first post! (when after introducing myself on the new member thread):thumbsup:
  2. BikeSDP Husqvarna
    Longmont, Colorado
    None @ moment
    990 Adv, Multistrada 1200, 500 EXC
    It's as sloppy a fit as was intended, apparently. In other words, it's normal.
    Welcome
  3. Bikyto Husqvarna
    Nor Cal
    Thank you! For some reason, I didn't get notification of your reply. Thanks again
  4. MotoXotica Husqvarna
    Vacaville
    they seem to get a looser fit as they get more use.both the buttons wear as does the rotor around the buttons.if the noise really is bothering you your floating rotor can be replaced with an older style rotor that does not float.dan
