rear rotor txc250
Discussion in '4 Stroke' started by Wadman, Nov 6, 2009.
  1. Wadman Husqvarna
    south carolina
    I noticed tonight that my rear wave rotor on my 09 txc 250 has some side to side play in it. Is this normal? I tried to tighten the bolts on them but they were already pretty tight.
  2. woodzi Husqvarna
    Waterloo, ON
    It is normal. It is a floating disk.
  3. Motosportz CH Sponsor
    That is a floating rotor, they are supposed to be loose. :thumbsup:
  4. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    Ya what both of them said...:D
  5. BlueHusky144 Husqvarna
    Staunton, IL
    Some play is normal but I have found out after a while that the hardened bushings wear and need to be rotated 180 degrees for their second life. On my 125, I started noticing it "rattle" a little more when I rev the bike in nuetral. No noticable difference in braking but I hate weird noises. KTM's are the only bikes that make strange noises, right?.....:D
    After you rotate them make sure you use blue loctite.
  6. Wadman Husqvarna
    south carolina
    Thanks guys.
