Rear shock rubbing
Discussion in 'TR650' started by Nick780, May 20, 2015.
  1. Nick780 Husqvarna
    83 Suzuki GS400E
    Was doing a quick scrub and check of the bike when I noticed this wear on the rear shock for the first time.
    Looks like it's rubbing on the spring...
    Anyone else have this happening? Cause for concern?
  2. drzcharlie Husqvarna
    Looks like you got a rock wedged in and it rubbed the case up and down until it was shaken loose.
  3. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Yeah they happen if you want a cheap fix for a year or so i cut the front innertube and made a shock sock to protect it a bit more, espesially required in muddy conditions, the rubbers starting to perish now but still have plenty of tube left.
  4. Nick780 Husqvarna
    83 Suzuki GS400E
    It's hard to get in there to check but there is definitely some clearance between the spring and the shock. Rock makes perfect sense.
    I'll keep an eye on it but I'm willing to wager that was it.
    Thanks,
  5. Clete Husqvarna
    Tigard, OR
    '01 CR/WR 250, '13 650 Terra
    '06 Suzuki SV650 (gone)
    I wish someone would make an aftermarket shock for the 650
  6. drzcharlie Husqvarna
    I have similar markings and I had a rock wedge in tight. I had to break the rock with a long screwdriver and hammer to get it out.
  7. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    They do, speak with Terry Hay at Shock Treatment
  8. glitch_oz Husqvarna
    AUS
    Strada
    The poster is in Portland, Oregon, USA!! :eek:
    More than likely wouldn't know Terry Hay from a jar of peanutbutter. :-)
    engineerk9 likes this.
  9. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    However Google "Terry Hay Shock Treatment" might give him a clue - Terry Hay is the the Guru who sets up majority of successful racers, GP, Superbike, MX, Enduro etc etc
    Shock Treatment Home Page www.shocktreatment.com.au/
  10. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Try this http://www.advrider.com/forums/showthread.php?t=922236&page=12
  11. sussurf Husqvarna
    Port Macquarie area, NSW
    Triumph Sprint 1050, Daytona 955i
    I have the same rubbing.
    Terry Hayes is a class act.
    Love the Ohlins can I have one?
  12. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    Terry can do much better & less than half the price of the Olins
  13. sussurf Husqvarna
    Did he make something for your Terra?
    I have to go & pick up some fork seals & bushings from him this week so I can talk to him about it.
  14. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    He did 2 new rear shocks for my ZRX, plus all the work on my Terra Shock & Forks, he's been doing all my suspension work on all my bikes for over 15 years (maybe longer)
    I have great regard for him & his work
    At some point l will get a new shock from him
  15. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
  16. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    There are better, less expensive motorcycles than the Husky, so I suppose it is all about preferences and options.
    I myself would be happy with a decent progressive rear spring on the current setup. For the front, I have no idea. Once the hot weather gets hear I have to tear the fronts apart anyway because of the clunk. At that time I will figure something out for that as well.
  17. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    RaceTech in the usa will look after you Terry Hay uses olot of their parts
