Rear wheel bearings.
Discussion in '610/630' started by pistolpete, Apr 10, 2010.
  1. pistolpete Husqvarna
    BC
    So we all know the te610 has 2 x 6005 bearings and 1 x 63005 bearing. The 6005 is 25 x 47 x 12mm and the 63005 is 24 x 47 x 16mm.
    The 63005 is a real pain to source, where the 6005 is readilly available at most bike shops and bearing supply shops.
    Would it be possible to use 4mm of spacer with a 6005 bearing? I am sure a decent machine shop could make up a spacer 4mm wide and just the width of the outer race. Basically the spacer would be an outer race reduced to 4mm across.
    Why would Husky make use of such a oddball bearing?
  2. ghte Husqvarna
    Bright, Victoria Australia
    I am surprised that the bearing is hard to get. Call up "all balls" and ask. On the 450's etc they are readily sourced items
  3. crem55 Husqvarna
    ma
    I got bearings and spacers from EE for $44 and the spacers are hardend.
